| Home > Help Needed / General Tech Chat > Not much happening on Number 2 Cylinder | |||||||
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
17th Nov, 2017 at 06:27:28pm
Guy’s,
’77 Clubman build thread
17th Nov, 2017 at 08:03:52pm
dp Edited by robert on 17th Nov, 2017. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Nov, 2017 at 08:04:53pm
too lean ? tried winding down the jet or pulling the choke on ?
17th Nov, 2017 at 09:14:13pm
something in the valve terrain gone a miss?
18th Nov, 2017 at 10:24:12am
On 17th Nov, 2017 robert said:
not a chance or blue paper towel of death stuck somewhere ? I hope not! But looking at the plot again with a fresh set of eye’s a bit earlier this morning, the effects to AFR on pulling the HT lead for Number one are nothing like that of 3 and 4 Cylinders, so this could be a blockage in the inlet tract for 1 / 2 cylinders, affecting 2 more than 1. It looks like I need to pull the inlet manifold off as see if I’ve been a complete cock and left something like rag/ towel in the port on Number 1 / 2. On 17th Nov, 2017 robert said:
too lean ? tried winding down the jet or pulling the choke on ? I have not since discovering this problem. I’d do that after I’ve looked in the ports. If not, I’ll pull the rocker cover and look at the valve train. Thanks for the suggestions. ’77 Clubman build thread
18th Nov, 2017 at 04:37:51pm
Sorted – or at least I know what’s wrong now.
18th Nov, 2017 at 05:29:30pm
Had I read this before you found it, I'd have guessed air leak on the manifold.
18th Nov, 2017 at 08:55:48pm
rub it down on a sheet of glass and some 40 grit ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Dec, 2017 at 08:22:58pm
So just to close this off.
