My current 4 point harnesses desperately need replacing as I originally took the cheap option to get the car on the road, with the intention of replacing when funds allowed.
3 Years down the line and I’ve still not done anything about it, but the current harnesses are just not that good ( they slip undone and I’m forever tightening them on the move.), plus one got broken on Saturday when I went to adjust the lap belt and the buckle got caught up in the hole in the seat.
So I’m looking at either of these as replacements:
OMP Racing 4M Harness
https://www.jjcraceandrally.com/race/saloon...cing-4m-harness
Or
Sparco 4 Point Driver Clip In Harness
https://www.jjcraceandrally.com/race/saloon...clip-in-harness
The question is does anyone have either of these fitted?
If so, could you measure the lap belt anchor bolt hole to the buckle?
As you can see from the picture, when in position the buckle is inside the hole in the seat, which makes it a pain in the arse to adjust…
I’m hoping, that either of the potential replacements will be shorter, which I think they look to be in the photo’s online.
Current length of those I have installed is ~260mm
Thanks
Graham
Edit: Wrong URL for Sparco product
Edited by Graham T on 10th Jun, 2018.
’77 Clubman build thread
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=618189
Siamese 5 port EFI testing
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=611675
