| Home > Help Needed / General Tech Chat > bmw k1200lt bmw k1200rs compression ratio | |||||||
5 Posts Member #: 11816 Junior Member |
16th Oct, 2018 at 05:20:47pm
hello all, i'am johan hogenbirk from the netherlands.
Edited by johan on 16th Oct, 2018. |
211 Posts Member #: 10890 Senior Member Twin Cam Turbo Build In Progress Rothwell, Northants |
16th Oct, 2018 at 09:24:48pm
1171cc with a head volume of 19cc, piston dish of 7cc, 4cc Gasket and zero dec height gives 10.8:1
17th Oct, 2018 at 12:08:45pm
Kind of related:
17th Oct, 2018 at 12:37:32pm
Bmw head gasket is 1.6mm thick and at least 6cc volume. It is possible there are two thickness head gasket for LT and RS but I’ve not come across that. On 26th Oct, 2004 TurboDave16v said:
17th Oct, 2018 at 01:23:30pm
oke thanks for respons, i will check out the p/n and thickness of the gasket |
17th Oct, 2018 at 01:33:59pm
i checked it but also the gasket is the same p/n ??????
17th Oct, 2018 at 08:24:25pm
longer con rod ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Oct, 2018 at 08:31:34pm
On 17th Oct, 2018 robert said:
longer con rod ? That trumps my answer, surely that’s it? |
18th Oct, 2018 at 09:01:14pm
Where did you find the info on compression ratio? I've seen miss prints in the BMW workshop manuals before now. On 26th Oct, 2004 TurboDave16v said:
18th Oct, 2018 at 10:45:18pm
I was intrigued by it and have been googling it quite a lot, those ratios are mentioned quite a lot in different places. I haven't found anything yet regarding the calculations
On 18th Oct, 2018 Sprocket said:
Where did you find the info on compression ratio? I've seen miss prints in the BMW workshop manuals before now. |
23rd Nov, 2018 at 10:33:18pm
i googled specs k1200lt and k1200rs |
26th Nov, 2018 at 08:29:52pm
what do you think is the difference in horsepower only by the camshafts or also a combi with the ecu |
