| Home > Help Needed / General Tech Chat > Dashpot Oil | |||||||
16 Posts Member #: 11921 Member |
22nd Dec, 2020 at 05:52:32pm
What's the thickest oil someone has ran in their dashpot?
22nd Dec, 2020 at 07:26:57pm
People use all sorts. Dash pot oil is 20w some use ATF some 3 in 1 oil most probably use 20w50 I think |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
22nd Dec, 2020 at 10:26:07pm
Just as a side thought, have you tried running a higher poundage dashpot spring?
27th Dec, 2020 at 10:49:44am
Is this on a turbo carb with the balance pipe still fitted? Going lean when going from cruising to accelerating can be caused by issues with the part throttle lean off on the carb. |
28th Dec, 2020 at 12:48:05am
Thanks for the replies guys.
327 Posts Member #: 1145 Senior Member North Wales |
28th Dec, 2020 at 07:35:17am
I had a bottle ages agohttp://www.minispares.com/product/Classic/Fuel/Carburettors/BDR125.aspx?1302&ReturnUrl=/search/classic/dashpot%20oil.aspx|Back%20to%20search. saves messing about. |
28th Dec, 2020 at 10:57:44am
If you have a search I believe I've previously read of members using two springs, but I cannot remember the result.
On 28th Dec, 2020 Glun34 said:
Thanks for the replies guys. I've got a higher poundage spring but not given it a go. I believe its a high boost spring as I'm currently running the standard yellow one, and its other one is quite a lot harder. Yes, turbo carb but I've got the balance pipe blocked off. found it was very lean with everything connected. |
28th Dec, 2020 at 04:15:01pm
The problem with using two springs is that it has two effects. It does slow down the rise of the dashpot and help to stop it leaning off, but it also changes in what position the dashpot sits when cruising at any particular throttle position i.e. the needle sits lower in the jet due to the extra spring pressure. In the short term you can fix one problem and create a new one. Edited by metroturbo on 28th Dec, 2020. |
28th Dec, 2020 at 07:21:29pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=139234
