| Home > Help Needed / General Tech Chat > quick throttle position change not smooth | |||||||
75 Posts Member #: 1956 Advanced Member |
25th Feb, 2021 at 08:38:38pm
25th Feb, 2021 at 11:49:26pm
Does putting thicker oil or a heavier spring in make any difference?
26th Feb, 2021 at 01:48:30pm
On 25th Feb, 2021 Turbo Phil said:
Does putting thicker oil or a heavier spring in make any difference? On a side note, any more info on your LED piston lift indicator? I made a mechanical one, but a nice electronic one would be better. Phil. Would be interesting to see. Need to sort out how I'm going to tune my mini |
26th Feb, 2021 at 06:59:46pm
Wouln’t a havier spring or thicker oil make is more lean? I paid extra attention to my lambda. It goes in the direction of lean. I’ll try some different springs.
26th Feb, 2021 at 07:00:25pm
And I’ll post some pictures of the LED system |
27th Feb, 2021 at 09:41:59am
There is some info on the excellent LED system here: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=617324 |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
27th Feb, 2021 at 10:05:45am
While searching for info for a side project recently it appears historically there has been mixed feeling on here with dashpot springs with some members stating that the (I believe green strongest) was sufficient, others saying that swapping springs made no difference. I recently read of members using two standard springs.
27th Feb, 2021 at 06:47:25pm
Thx Metroturbo, saves me finding the pics 😊 |
27th Feb, 2021 at 06:48:29pm
I’m driving with the standard plenum with the g40 recirculation valve in front. |
174 Posts Member #: 9128 Advanced Member |
27th Feb, 2021 at 10:01:43pm
What have you done with the part throttle lean off pipe ? If you've still got it connected as standard try either disconnecting it and blocking it off. Or leaving it as is and restricting it, with a clamp. |
28th Feb, 2021 at 08:45:32am
Thicker oil will make it run momentarily richer as it restricts the rise of the piston on a snap increase in throttle opening. Restricting the upward movement after opening the throttle has the affect of increasing the air velocity over the bridge of the carb, which reduces the air pressure over the bridge, and means more fuel is drawn out of the needle.
On 26th Feb, 2021 remko said:
Wouln’t a havier spring or thicker oil make is more lean? I paid extra attention to my lambda. It goes in the direction of lean. I’ll try some different springs. I think it has something to do with the suddenly rise of boost, due to supercharger instead of turbocharger. Is it possible that the pressure rise in carb is quicker then pressure increase in fuel bowl? |
28th Feb, 2021 at 01:18:29pm
Wouln’t a havier spring or thicker oil make is more lean? I paid extra attention to my lambda. It goes in the direction of lean. I’ll try some different springs. I think it has something to do with the suddenly rise of boost, due to supercharger instead of turbocharger. Is it possible that the pressure rise in carb is quicker then pressure increase in fuel bowl? No. You do not want the dashpot to rise quickly, that is what causes the lean condition if that is the problem you are experiencing. Log fuel pressure, MAP/boost and AFR's at a minimum. Type of boost does not matter. 9.85 @ 145mph
2nd Mar, 2021 at 05:02:47pm
Thanks Dilligaf and Metroturbo! Plugging this pipe solved my problem for 90%!
2nd Mar, 2021 at 05:03:54pm
Once this is solved I’ll switch over to a smaller pulley. Boost will rise from 0,5 bar to 0,75 bar! Edited by remko on 2nd Mar, 2021. |
