| Home > Technical Chat > Are my valves too big? | |||||||
25th Nov, 2005 at 11:18:41pm
Hi, VEMs Authorised Installer / Re-seller. K head kits now available!
25th Nov, 2005 at 11:53:46pm
I did have 37.5 mm inlets and 31.5 mm ex valves in my 1380 and the head did crack a couple of times, so I don't like to use such big ones in a turbo car.
Edited by Miniwilliams on 25th Nov, 2005. Best 1/4 mile 13.2 seconds @116 mph
26th Nov, 2005 at 04:42:47pm
27th Nov, 2005 at 04:07:05pm
with intercooler is a must!
27th Nov, 2005 at 06:36:03pm
Bens right intercooler is a good idea.
27th Nov, 2005 at 07:19:42pm
matt, just out of interest, who welded your head up? I seriously doubt it! |
27th Nov, 2005 at 10:36:16pm
Sadly it was a local firm that now has closed down, it's a real shame as it was top class work. :( Best 1/4 mile 13.2 seconds @116 mph
27th Nov, 2005 at 11:54:53pm
On 27/11/2005 22:36:16 Miniwilliams said:
Sadly it was a local firm that now has closed down, it's a real shame as it was top class work. :( When you eventually got anything you took to them back
-MINI CLUBMAN 1380 TURBO- |
28th Nov, 2005 at 07:15:58am
I have had 2 heads with 36/31 mm Rimflos. Both had offset exhaust valves and I had no problems with cracking. First head was totally ruined with valve seat erosion, the current head has same problem, however to a lesser extent. |
28th Nov, 2005 at 06:27:46pm
Edited by Bat on 28th Nov, 2005. VEMs Authorised Installer / Re-seller. K head kits now available!
29th Nov, 2005 at 08:14:07am
I ran a T3 until autumn 2004 when I tore the car apart for bare metal respray. It has not been painted yet... I sold the T3 and intend to fit a Mitsubishi TF035 which is about the same size as T2. Could be even smaller, maybe between T15 and T2. I have had the new turbo for 4,5 years but the T3 refused to let go so I never bothered to swap it |
29th Nov, 2005 at 08:16:03am
Seems I took some pics of the turbo and the manifold years ago, see http://www.geocities.com/jharkola/1380turbo6.html
29th Nov, 2005 at 04:05:31pm
looks great Jukka, and what a top manifold you've made. Best 1/4 mile 13.2 seconds @116 mph
29th Nov, 2005 at 07:45:46pm
Quality bit of workman ship on that manifold. -MINI CLUBMAN 1380 TURBO- |
30th Nov, 2005 at 06:48:17am
It´s not that bad and only cost like 30 quid or so in parts. The 90 degree elbows were standard DIN size but they had to be ordered since it is not that common size in local industry. |
31mm. Obviously the inlet is pretty big too! Do I have too much valve and not enough head to prevent cracking?
