Home > Technical Chat > spec of an MG metro cam? Turbo Dave - you may be able to help me!
Choppo
Member #: 409
What is the spec of an MG metro cam? Anybody know – TD perhaps?
I have heard its similar to the kent 256, with a powerband between 1000 and 6500 rpm?
Any help would be ace?
Choppo*wink*
Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
bad guy: What's the easy way?
Hannibal: That WAS the easy way.
KC 500 is exactly the same as an MG metro cam. So:
Make Model Rover Mini Metro
Part Number 500
Application Mild Road
Power Band 1500 - 6000
Cam Lift 6.67mm
Valve Lift 8.12mm
Duration Inlet 252 Degrees
Exhaust 268 degrees
Timing Figures 16/56 59/29
Valve Timing 110 Degrees
Valve Clearance 0.40mm
Info from here
http://www.kentcams.com/
Wil
Edited by wil_h on 14th Dec, 2005.
I've just realised i don't have an MG metro cam anymore...
Some welsh boyo 'borrowed' it...
Now, I'm 2700 miles away from the cam i was going to swap over to this winter *frown*
it's in my kitchen and the moment dave, shall I post it to you?
LOL! I was only jesting.
Don't post it yet my Welsh friend!
I may be heading to the UK sometime in Jan/Feb - so i'll keep you updated!
I was timing my camshaft today, and ended up with 111 degrees. Damn, I guess I need to get it to 109 for allowing the chain to stretch a bit.
Or if you prefer good old fashioned measurements:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8343
Yes, but we still agree that it should be timed in at 110degrees?
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
nop,
time it a
fab
Member #: 100
Paris\' suburb
at 108°
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
OLD THREAD WARNING!
lol
AlexF
Look who dug it up *wink*
evolotion
Member #: 83
Glasgow, Scotland
is ACDodd's list of camshaft spec and timings not still kicking around somewhre? remember it from the old miniclassic board.
Denis O'Brien.
Users viewing this thread: none. (+ 2 Guests)
