Home > Help Needed / General Tech Chat > Front subframe mounts
clubbyestate
Member #: 478
Ooop Norf (Cumbria)
Just thinking about replacing the front subframe mounts on my estate before the engine goes in.
Can this be done without removing the subframe completely ?
It currently has no other connections to the car so now would be the ideal time to drop it out and fit a set of polyflex (or similar) mounts.
What would anyone recommend I fit ?
Clubbyestate : Brown and loud - fast soon !
Fit solid mounts, nothing else it going to take the hammering they'll get with a turbo motor. It'll make the handling a little sharper aswell! You can fit rubber mounts on the toeboard if you want to reduce the noise transmitted from the subframe(assuming you haven't got a flip front!) No need to remove subby completely, just unbolt, lower and fit new...... sounds dead easy like that!
Gavin. :)
Edited by Bat on 23rd Dec, 2005.
andeh
Member #: 97
Near Daventry, midlands
duno how old the car is, but if it originally had rubber mounted subby keep the toeboard mounts rubber, the solid ones can (and probably will) cause the toeboard to crack. Solid tower mounts are great (seriously), road noise does increase, but only really noticable when going over bumps. Solid mounted front ones are u/s and expensive, so i'd replace these with std.
Edited by andeh on 23rd Dec, 2005.
andeh , here, here to that.
I only have standard ones, and they are fine. And i think you can fit standard one with out to much work and without taking the frame out.
clubbyestate
Member #: 478
Ooop Norf (Cumbria)
Top advice folks - thanks very much !
It's a 79 clubby estate (you'd never guess !) and it really needs front floors replaced.
So the best plan is to fit solid tower mounts (I have a 16V Vauxhall Mini with nylon top mounts that work very well) but leave the remainder standard.
Cheers and merry xmas to you all ! *happy*
turboestate
Member #: 362
durham area
I have a 1978 clubman estate trust me youl recieve some funny looks as you overtake people LOL
solid tower mounts is the way to go (cant hear anything for the gearbox anyway LOL
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
clubbyestate
Member #: 478
Ooop Norf (Cumbria)
Sounds good !
I'm going to keep the external 'russet brown & rust' theme too !
Is yours brown too ? *tongue*
turboestate
Member #: 362
durham area
it was in plases its now like this- http://i18.photobucket.com/albums/b122/tur...clubmanside.jpg
http://i18.photobucket.com/albums/b122/tur...boenginebay.jpg
merry xmas
______
/___|_____
_ (@)___(@)
clubbyestate
Member #: 478
Ooop Norf (Cumbria)
Beautiful car mate !
Mine will never look that good - but I do have a 16V cabriolet to play with instead !
Merry Christmas to you too ! *happy*
andeh
Member #: 97
nice engine bay!
