| Home > Technical Chat > Piston Source????? | |||||||
29 Posts Member #: 800 Member Central Kentucky |
24th Dec, 2005 at 08:37:12pm
Where can I get 1275 forged pistons with enough dish to keep it streetable on 10psi? All I have found is 1293 dished pistons, and 1275 non-dished. I have looked on sites like Avonbar, JE pistons, and Mini spares with no luck, where should I be looking? If you are running a 1275 T3 with around 10psi what kind of pistons are you using?
Caution- objects in mirror are LOSING! |
24th Dec, 2005 at 09:57:26pm
Whats so bad about 1293 ?? Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
25th Dec, 2005 at 05:54:58pm
You can get Omega cast ones ion 10cc. With a decent head, that'll be fine.. On 13th Jul, 2012 Ben H said:
25th Dec, 2005 at 08:12:09pm
27th Dec, 2005 at 03:48:58am
Nothing is "BAD" about a 1293 but I live in the states and no one would be able to bore it out. Caution- objects in mirror are LOSING! |
27th Dec, 2005 at 04:39:46am
uh?
27th Dec, 2005 at 10:35:34am
If you find a shop with a Sunnen CV-616 Honing machine they should be able to rough hone the block out without boring it. I've done this in the past to a few blocks and it works great and even better if you use a head plate to eliminate the head stud shadows in the bore. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
27th Dec, 2005 at 03:59:05pm
http://www.minimania.com/web/threadid/7285...3/msgthread.cfm On 17th Nov, 2014 Tom Fenton said:
27th Dec, 2005 at 05:24:38pm
Dave it's been 10 years since i took 20&40thou out of a block on a CK-10 but the results were spot on.
27th Dec, 2005 at 08:11:52pm
Well reading into it more following that article has made me decide on having any blocks i need machining sending to that 'compcar' fella - or finding someone locally with a Sunnen... On 17th Nov, 2014 Tom Fenton said:
28th Dec, 2005 at 09:18:10am
On 27/12/2005 17:24:38 Doodmeister said:
Dave it's been 10 years since i took 20&40thou out of a block on a CK-10 but the results were spot on. The interesting thing was just just deglazing the block first to see the points where the head studs pull back the cylinder walls when torqued up.. Thing is you wouldn't notice this if your not honing with a good head plate to simulate head stud torque, it's amazing how much the studs pull on the bores. I've just read that two guys in the US did the exact same thing as this. They found that the block distorted almost NIL! This was before and after the honing plate was fitted. Which measurments did you come up with? On 13th Jul, 2012 Ben H said:
28th Dec, 2005 at 09:57:29am
V. The block was a used turbo item with around 15000 miles on it before it got the hone treatment.
28th Dec, 2005 at 11:04:15am
What I heard of ( I'll try to find it) was that they had taken measurments BEFORE fitting the plate, and then after. This was done on various places down the bore. The difference was so little that they concluded that the honing plate was uneccessary.
29th Dec, 2005 at 04:13:35am
oooh.. thats interesting. explains why i had bother finding a machine shop around here that would offset bore a block. turbo 16v k-series 11.9@118.9 :)
29th Dec, 2005 at 01:28:57pm
Why? that has got nothing to do with this... It all about which boring equimpent they use. On 13th Jul, 2012 Ben H said:
29th Dec, 2005 at 04:18:55pm
i was reffering to the link above vegard, where the chap describes the difference between "boreing" and "honeing" :) turbo 16v k-series 11.9@118.9 :)
:cool::cool:
