Home > Help Needed / General Tech Chat > stuck t2
benjamin
Member #: 621
nsw austalia
well i need to rotate the center of my t2 turbo so that the oil return is facing down.
iv undone bothe the circlips but the center is stuck. The compressor side turns but the center seems to have rusted to the exhaust housing?
helllllpppppppp
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
Kean
Member #: 341
aka T2clubby
South Staffs
I thought the hot side was held on with 4 bolts?
benjamin
Member #: 621
nsw austalia
well mine is a circlip on both sides, maybe our aussie t2's are different
Edited by benjamin on 29th Dec, 2005.
Kean
Member #: 341
aka T2clubby
South Staffs
Ahh I see, have you managed to get the circlip all the way out or just loosen it?
Might just need some good penetrating spray and some brute force
Once you've got the circlip out, you may need to warm up the housing and knock it loose with a hide or copper hammer. I know it sounds a bit brutal, but I was told to do this by a turbo repair company. Worked OK 8) Bit scary though! *surprised*
Gavin. :)
I had a T2 with the Circlip once - I heated it, and heated it, and heated it, and knocked the living crap out of it with a copper mallet, but it didn't budge. Not once. :(
Just making sure you're aware...
ps - that wouldn'y be a 0.63 turbine (exhaust) housing would it? These are a little too large for a 1300 - even a 1380 will struggle to spool one of these up properly; just makig sure you're aware...
benjamin
Member #: 621
nsw austalia
its been soaking in penetrative spray for 2 days now and wont budge*frown* i think this will have to go to the garrett turbo place as i dont think its gonna budge, although i havent tried heating it yet.
it is a .47 exhaust housing
Cool - that'll be sweet then!
Turbo places usually have MASSIVE (like 5 times the size of a scrapyard cutting torch) Torches for quickly heating the housing.
I think this is the key - putting loads of heat into it rapidly so it can't pass all this heat into the centre-housing, hence it WILL expand more and WILL come apart...
benjamin
Member #: 621
nsw austalia
i have another question, i having troubles fitting the oil feed to the turbo. i bought this oil feed kit:
http://cgi.ebay.co.uk/Mini-or-Metro-Turbo-...1QQcmdZViewItem
iv been to pirtek and enzed both saying i cant fit it to the turbo.
can you ppl with t2's show me how yours is done
On 16/12/2004 22:53:29 TurboDave said:
The T2 uses 7/16" x 18tpi and 1/2" x 21tpi or something like that (i've got the exact pitch written down somewhere,
From
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=3231
I Can't remeber what the pitch is exactly - I have it at work (3rd of Jan I'm back) so can check then.
Here is a (bad) pic of mine from a few years back...
benjamin
Member #: 621
nsw austalia
7/16'' x 24tpi , so lookes like ill have to get something lathed up
benjamin
Member #: 621
nsw austalia
is it pipe thread? or unf
It's a special thread pitch...
Make a drawing and take to a machine shop...
I've got two banjo bolts made exactly the same but for the Two different threads found on the T2 units - so whichever one i swap to, i've got the right union.
When making the drawing, be very critical on the dimensions as you don't want the thread to bottom-out. I also added a countersink to the end of my unions to give clearance around the 'inverted flare' that the stock oil feed bolted to - you may or may not have this...
Edit - note that you do appear to have this so will need the countersink (or have less thread length):
Edited by turbodave16v on 30th Dec, 2005.
SumpNut
Member #: 28
Avonbar got hold of a banjo for mine @ 24tpi and 7/16ths
benjamin
Member #: 621
nsw austalia
ok all good getting this made up
and the turbo shop opens on the 3rd so ill go get the turbo unstuck then*smiley*
Are you mounting it on the metro manifold? if so - you're going to have probs. There is literally 2mm between the top of my union and the 13mm AF nut holding the turbo to the manifold.
A complete banjo bolt is the only answer in this case- which of course probably means your hose won't do as the 7/16 is larger OD than the hole in your banjo on your oil pipe... :(
benjamin
Member #: 621
nsw austalia
im using a manifold i made, but that stud still could be a problem
well ill see, click on my signiture for pics of the manifold
