| Home > Technical Chat > Compression ratio's - how low can you go ? | |||||||
31 Posts Member #: 478 Member Ooop Norf (Cumbria) |
3rd Jan, 2006 at 09:09:40pm
Need some advice folks :
Clubbyestate : Brown and loud - fast soon ! |
3rd Jan, 2006 at 09:14:04pm
If it's got low-compression pistons, you can also assume these are 'low quality' and might not be too accepting to a 100+% increase in power than the original (at a guess) 60hp engine had... On 17th Nov, 2014 Tom Fenton said:
3rd Jan, 2006 at 09:16:51pm
I would disregard the metro van and 8.0:1 CR. In order to put up with boost pressure, at a guess metro turbo pistons and cylinder head will have been used, so more likely your CR is probably 9.4:1.
3rd Jan, 2006 at 09:34:02pm
Thanks Tom & Dave, that's excellent advice !
809 Posts Member #: 224 Post Whore Katy TEXAS |
6th Jan, 2006 at 01:07:23pm
Tom,
6th Jan, 2006 at 03:29:18pm
The engine is running but not under load yet, as the car has no doors etc. Also it is yet to be set up. The head gasket is the Group A item.
7th Jan, 2006 at 01:08:34am
The 125-130bhp will be easily achivable with 15psi with the engine built and set up to avoid detonation. -MINI CLUBMAN 1380 TURBO- |
7th Jan, 2006 at 09:15:27am
you should be able to get that with lowering cr to much and run about 10 to 12 psi i would have imagined, use a decent intercooler get set up well, my rr man uses det cans which help no end. always looking for them bigger bunches of bannanas |
