| Home > Help Needed / General Tech Chat > carb upgrades | |||||||
19th Jan, 2006 at 09:20:44pm
hello, apart from a full rebuild what else would you recommend i do to my carb, upgraded dash pot spring? bi metallic strip thingy? thanks |
19th Jan, 2006 at 10:18:29pm
Bi met thingy,
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
19th Jan, 2006 at 10:21:38pm
what does blocking off the by pass hose do, which one is the by pass hose, is it the one which would be a fuel over flow on n/a carb "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
19th Jan, 2006 at 11:07:59pm
whats the original throttle disc like? already on the dashpot cover should add around 50bhp lol
19th Jan, 2006 at 11:25:33pm
On 19/01/2006 23:07:59 gav said:
whats the original throttle disc like? already on the dashpot cover should add around 50bhp lol The standard one has a little spring "poppet" thing fitted, replace with a solid disc as Dave suggested.
119 Posts Member #: 772 Advanced Member new york |
20th Jan, 2006 at 12:56:11am
where can you get this solid disc?
20th Jan, 2006 at 01:24:05am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2785
21st Jan, 2006 at 12:46:34am
why is a solid butterfly needed? ive been running the std type with the poppet valve in my car |
21st Jan, 2006 at 12:50:55am
Its not strictly needed, but think about the percentage cross sectional area the poppet occupies at full throttle opening, and the disruption to flow.......
21st Jan, 2006 at 12:54:03am
i was thinking that might of been the reason and thats why it was going to go for this year |
21st Jan, 2006 at 01:04:02am
Yup bin it, solid butterfly comes with the carb rebuild kits.
21st Jan, 2006 at 05:47:36am
It also leads to a sluggish dump/blow-off valve operation in many cases. You'll probably find your DV sounds a lot different if you change it... On 17th Nov, 2014 Tom Fenton said:
21st Jan, 2006 at 04:06:30pm
ah thanks and yep the dv did sound a bit crap. |
22nd Jan, 2006 at 12:20:57pm
sorry anyone know what the hi-flow needle valve on avonbars website is needed for, or does this also come in the rebuild kit? |
22nd Jan, 2006 at 04:07:14pm
Speak to Avonbar. They have several needles... On 17th Nov, 2014 Tom Fenton said:
25th Jan, 2006 at 05:33:05pm
On 22/01/2006 12:20:57 gav said:
sorry anyone know what the hi-flow needle valve on avonbars website is needed for, or does this also come in the rebuild kit? A standard needle valve comes with the Burlen rebuild kit. The Avonbar item may be a modified needle valve orafice ? I was advised when having fuelling probs to drill the float bowl needle valve orafice to 2.9 mm to improve flow. This was a trick suggested by Avonbar. Perhaps it's this they're selling. Phil.
