Home > Help Needed / General Tech Chat > Digital Dash
Dicanio
Member #: 91
How difficult would this be to fit
http://cgi.ebay.co.uk/DIGITAL-SPEEDO-KAWAS...1QQcmdZViewItem
Personally i don't think it would be to hard, but have you guys got any experience of this type of dash?
Nick
Member #: 154
Midlands
Speed Sensor: No Contact Magnetic Sensor
Tacho Input: CDI or Ignition-coil signal
should go straight on then i reckon according to the description. will just be a magnetic signal like the push bike speedo's. Even the rev counter may work.
If you do a search on this there were two or three suggestions on where to mount the speed sensor. *wink*
Gavin. :)
Edited by Bat on 21st Jan, 2006.
jimmy
Member #: 829
essex
the rev counter is CDI (capacitor discharge ignition) mini are not
mini fuel gauge you need to check resistance is 100 ohms on the sender:cool:
Edited by jimmy on 21st Jan, 2006.
1293 Turbo mini
evolotion
Member #: 83
Glasgow, Scotland
it quite clearly says "Tacho Input: CDI or Ignition-coil signal" .. i.e. it will work off the -ve side of the coil of a single coil engien, or you can use the diode trick as posted on msefi.com if you have a waisted spark (2-coil) setup.
Denis O'Brien.
jimmy
Member #: 829
essex
is this unit for a 4 cylinder engine
1293 Turbo mini
i'm guessing with it being for a quack then yes.
these look good for the money
Nick
Member #: 154
Midlands
http://www.trailtechproducts.co.uk/store/erol.html#1x0&&
i've been looking at these, thinking about using one in my new car rather than the bike speedo i've got at the minute, mainly just because they've got a backlight!
*edit* links a bit shit, takes you to the main page, just click on the 'Trail Tech Lynx ATV and Motorcycle Computer'
http://www.trailtechproducts.co.uk/store/computer.htm
Edited by Nick on 25th Jan, 2006.
that looks good bud.
tempted with something like that myself!
