| Home > Help Needed / General Tech Chat > piping up intercooler problems | |||||||
40 Posts Member #: 677 Member Buckinghamshire |
15th Feb, 2006 at 11:03:56pm
i have a clubman and i am trying to pipe up a R5 intercooler, i have sourced a different inlet for the plenum chamber from a meastro turbo in the brakers, but i am having a problem trying to get an samoc elbow on the pipe that comes out of the top of the turbo as it is very tight against the inlet manifold stopping an elbow from being push on fully, which in turn makes it tight underneath the inlet to the plenum.
16th Feb, 2006 at 03:49:56pm
16th Feb, 2006 at 08:47:32pm
You could either make one up or as i have done, unbolt, turn it 180degrees (gives better clearance)and weld a larger outlet pipe on to go with the rest of the intercooler hosing.
-MINI CLUBMAN 1380 TURBO- |
17th Feb, 2006 at 11:28:28pm
Cheers, turned it 180 degrees and it did the trick, thanks for the tip. |
18th Feb, 2006 at 09:09:54am
yep thats what i done on mine it works a treat. always looking for them bigger bunches of bannanas |
