Home > Technical Chat > Mirage manifold and engine tilting
MaltaMini
Member #: 510
Malta
As per title - is it necessary to tilt the engine to fit a T25 on a Mirage manifold, or will it fit on a standard subframe?
I want to use this system, but would rather move the engine to the position it would be in an mpi, than tilt the engine.
Can anyone please tell me as I keep getting different views?
I donated, but somehow didn't get the label! :(
Kean
Member #: 341
aka T2clubby
South Staffs
Mine is slightly tilted forward, only very slightly mind.
I'd rather tilt it than move it forward, so as to keep as much space up front for intercooler etc
SumpNut
Member #: 28
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5742
These show the engine in - no stabalisers fitted so it is not tilted forward.
There is clearance - but not that much.
It is a t25 rather than a t2 by the way
MaltaMini
Member #: 510
Malta
Is that on a standard subby?
That's a lovely fit! I'm starting off with a T2, then probably upgrading to a T25 hybrid in the future, so I guess I'll be allright... the thing is that the Mini's going to the bodyshop soon for a concours paintjob (metalflake and flames) so I dont want to butcher the bulkhead aftrwards.... Cheers!
SumpNut
Member #: 28
standard subframe all the way.
Relocating engine mounts or auto subframes is un-nessasary.
On a standard metro turbo installation on an all metal standard fitment front it is tight round the front - so why move it forward!
SumpNut
Member #: 28
i just noticed your signiture.
PM alexb to sort that out!
