| Home > Help Needed / General Tech Chat > Oil cooler | |||||||
57 Posts Member #: 911 Advanced Member |
26th Feb, 2006 at 11:59:47am
Just been looking throught the old poasts about oil coolers and i noticed there seems to be a disagreement on if you need one or not.
26th Feb, 2006 at 12:05:52pm
fit the temp gauge. then see! you can always slow down to cool it down during the test stage |
26th Feb, 2006 at 12:09:33pm
cheers.
26th Feb, 2006 at 12:20:37pm
whatever you fancy. They do the same job.
26th Feb, 2006 at 01:09:25pm
Im pondering the same as you roadkilla...
26th Feb, 2006 at 01:18:42pm
rsroadkilla, oil cooler or not.??
26th Feb, 2006 at 01:41:22pm
HI,
26th Feb, 2006 at 06:18:52pm
so i should just use a stat then?
1300 Posts Member #: 829 Post Whore essex |
26th Feb, 2006 at 07:11:05pm
when you buy the stat you cut the two pipes to the cooler and fit in the stat inline when the oil is cool the stat bypass the cooler when the oil is hot it will flow throw the cooler :cool: 1293 Turbo mini
27th Feb, 2006 at 12:46:36am
Ive been giving this a bit of thought recently, had a few smooths, so bare with me and hear me out "Turbo's make torque, and torque makes fun"
27th Feb, 2006 at 10:30:34am
Say I fit an oil cooler with a 95 dgree thermostat. I start the engine, get it hot, everything goes fine untill i hit the 95 degree mark, then the stat opens and a load of (potentially) icy cold oil thats been sat in the cooler for the last 20 mins or whatever gets forced through the engine... could this be damaging in anyway? in short Yes! but its not as bad as a constant cold flow of oil
27th Feb, 2006 at 10:41:24am
is it as going to have worse implications than oil thats too hot?
27th Feb, 2006 at 10:56:20am
oil too hot is fatal for all engine internals.
27th Feb, 2006 at 10:56:22am
i fitted a cooler to mine last summer. i dont have an oil temp gauge at the minute but i'd noticed on motorway runs that my oil pressure was dropping dangerously low. fitted an oil cooler and its been fine ever since, but i'm still going to fit a temp gauge just so i can monitor it properly. On 20th Oct, 2015 Tom Fenton said:
27th Feb, 2006 at 11:00:40am
I supect that the stat wouldn'd suddenly open allowing all the 'cold' oil straight into the engine, rather it would be a slow dribble mixing with the warm oil.
27th Feb, 2006 at 11:13:47am
On 27/02/2006 11:00:40 wil_h said:
I supect that the stat wouldn'd suddenly open allowing all the 'cold' oil straight into the engine, rather it would be a slow dribble mixing with the warm oil. Wil i hope so, but thinking about it, at part opening, the oil cooler will basically be plumbed in parallel to the oil system, so that probably wouldnt promote much flow...?? "Turbo's make torque, and torque makes fun"
27th Feb, 2006 at 05:12:33pm
well im not going to bother, im just going to run a temp gauge and see what happens!
27th Feb, 2006 at 07:20:38pm
ive not got a temp guage so dont know temp. suppose i should fit one while me engines in bits ummmm.
27th Feb, 2006 at 07:31:58pm
i`ve run a oil stat and the stat opens slow so the hot oil goes in the cooler at said 95 if the oil cools down the stat closes back up so the stat is like a switch it will reg on temp of the oil in the engine Edited by jimmy on 27th Feb, 2006. 1293 Turbo mini
31 Posts Member #: 448 The name's Mystic. Graham Mystic. |
27th Feb, 2006 at 09:41:58pm
Couple of things
28th Feb, 2006 at 01:11:23pm
On 26/02/2006 13:41:22 Bat said:
HI, I've not got mine running yet, but I've got a stat to go on. I've read on here that the standard Mocal stat runs too cold and you need to contact them for a hotter opening one. is there a way to mod the std mocal stat to open at a higher temp? save forking out for the upgraded job.... "Turbo's make torque, and torque makes fun"
28th Feb, 2006 at 01:59:40pm
the innards of my stat...click for bigger shots.
28th Feb, 2006 at 05:32:44pm
I'm with Benross on this one. I've run without an oil cooler for the past two years. I found under normal driving and even "spirited" road use that the oil never got hot enough to need an oil cooler.
28th Feb, 2006 at 10:48:28pm
think im just going to fit one, but make a removable cover so i can cover it up as necessary. :)
