| Home > Help Needed / General Tech Chat > my cam timings | |||||||
66 Posts Member #: 775 Advanced Member stourport-on-severn, worcestershire |
3rd Mar, 2006 at 06:13:13pm
i have timed in my phase 2 cam. i have bought the kit so new followers have been fitted. im using the mini sport ultra light timing gears. the times are as follows;
If in Doubt, go flat out !!! |
3rd Mar, 2006 at 06:25:27pm
Not sure what your saying, but if the instructions say to time it in at 110deg, then inlet no.1 should be at full lift when the crank is 110 deg btdc.
3rd Mar, 2006 at 06:31:15pm
yeah sorry. i havent got a verneer timing gear so all i have done is mach up the dots.when checking it with the protractor it is 5deg out. If in Doubt, go flat out !!! |
3rd Mar, 2006 at 06:38:03pm
Ah !!! Well you need to get yourself a woodruff/offset key so you can set the timing correctly. They are available in offsets of 1-9 deg. I would suggest advancing it a couple of degrees to allow for chain stretch. You don't want the cam timing retarded at all though.
3rd Mar, 2006 at 06:41:58pm
The numbers you quote seem a bit odd. What method are you using?
3rd Mar, 2006 at 06:47:19pm
thats the same method im using. i even used keith calvers method. have i done somthing wrong then? what is a woodruff key? If in Doubt, go flat out !!! |
3rd Mar, 2006 at 06:50:38pm
Available from MS
3rd Mar, 2006 at 06:52:17pm
You know the key that sits in the cam and the pulley slots onto ? Well it's one of these that is offset, because you don't have a vernier you can use these keys to obtain the correct cam timing.
3rd Mar, 2006 at 07:14:52pm
Edited by Bat on 3rd Mar, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
3rd Mar, 2006 at 07:21:38pm
I have read one or two degrees doesnt make much difference. However for every degree after that it is said to account for losses as much as one bannna per degree.
3rd Mar, 2006 at 07:25:46pm
AVONBAR do a set of offset keys 3,5,7,9.deg as a small packaged set
3rd Mar, 2006 at 09:32:01pm
doesnt the phase 2 have to be timed to 108 degrees?
3rd Mar, 2006 at 10:30:36pm
yes that is correct. exactly how i have done it. The information sheet that piper provided with the cam says 110deg not 108deg. If in Doubt, go flat out !!! |
1300 Posts Member #: 829 Post Whore essex |
3rd Mar, 2006 at 11:13:03pm
I no i`m late on this post but the time gear you have is there a row of allen key screws on the cam pully ?
Edited by jimmy on 3rd Mar, 2006. 1293 Turbo mini
3rd Mar, 2006 at 11:26:17pm
when you time the cam in i put a dia gauge on the piston to find tdc set time disc then turn engine clock wise to you are 10 deg before max lift take read then go over max lift to 10 deg add the two and then half it and that is the timing of your cam 1293 Turbo mini
4th Mar, 2006 at 09:10:25am
phil you should have said atdc not btdc eg 110 atdc always looking for them bigger bunches of bannanas |
4th Mar, 2006 at 10:42:25am
Oh shit, yeah well spotted. lol. |
4th Mar, 2006 at 12:49:09pm
Like Turbo Phill said, if they say to time it in a 110, if your using a new chain, time it in 3 or so degrees before that to accomodate chain stretch (if its a new chain).
4th Mar, 2006 at 07:31:51pm
avonbar say 108 degrees
5th Mar, 2006 at 09:54:11pm
beware of timing chains
5th Mar, 2006 at 11:25:08pm
righto, if avonbar say 108, if it were me id time it in around 105.
5th Mar, 2006 at 11:28:44pm
I wrote a guide on how to do this, look in the "How To" section...............
5th Mar, 2006 at 11:29:53pm
Hey presto
6th Mar, 2006 at 10:14:02am
im getting confused. the leaflet from piper says 110deg so does tom in his write up, and other people say 108deg. which one is it? only i have got to order my woodruff key and i dont know the degree because of this confusion. mine is set at 106deg. If in Doubt, go flat out !!! |
6th Mar, 2006 at 10:38:15am
It is not a set figure, it depends on the individual camshaft you have. So, the one I has was 110 deg.
