| Home > Help Needed / General Tech Chat > I need some Info | |||||||
40 Posts Member #: 677 Member Buckinghamshire |
4th Mar, 2006 at 11:29:40pm
A standard metro turbo engine set up with ECU, is set to give 4psi boost upto 4000 rpm and then 7psi after that?
26 Posts Member #: 755 Member Portugal |
5th Mar, 2006 at 12:57:29am
Thats a good question i also have some doubts on that matter...
5th Mar, 2006 at 01:13:10am
But in my lump i the wast gate actuator is directly connected to the compressor housing
5th Mar, 2006 at 02:17:19am
Thanks for the info.
5th Mar, 2006 at 06:53:55pm
you NEED a boost pressure guage! otherwise bang. no longer a series, but still 1.3 turbo.
5th Mar, 2006 at 09:39:23pm
hope this helps heres my set up
9th Mar, 2006 at 09:01:51pm
Sorry for being a grave digger but WHAT ABOUT THAT VAlVE in the plenum??
9th Mar, 2006 at 11:33:19pm
Edited by Bat on 9th Mar, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
9th Mar, 2006 at 11:42:53pm
ok thanks mate
