Home > Help Needed / General Tech Chat > pic of full turbo exhaust
benfredjosh
Member #: 927
port talbot, south wales
has anyone got a pic of the mini turbo exhaust system fully assembled? i know its a long shot, its just i dont quite get it? thanks very much!*tongue*
Kean
Member #: 341
aka T2clubby
South Staffs
Hope this will help
There is the manifold with turbo mounted onto... the shiny pipe to the right of the turbo is the downpipe which connects to the exhaust system after that its just a normal exhaust, pretty much.
benfredjosh
Member #: 927
yeh it does help thanks i am just confusd by the way the downpipe connects, does it just connect 2 the center section of the exhaust? thanks!
yes, do you have the right downpipe?
its a maniflow on you need, available from places like avonbar
benfredjosh
Member #: 927
i think i will order the full system maniflow turbo exhaust for mini turbos what u thnk?
good idea, this will then fix onto the cast outlet pipe of the turbo, although you will need to grind out the clamp slightly to make it fit
Are you using a T2 or T3? If it's a T2 like in the picture above, the Mirage manifold comes with the downpipe, so you just need the exhaust as if you were fitting it to a LCB *wink*
benfredjosh
Member #: 927
i am hoping to use the standard exhaust manifold and fit a t2 to that manifold? like jimster has done? i thnk? what will i need to do to do this then?
Nick
Member #: 154
Midlands
you'll need a custom one off downpipe making up then dude...
*edit* 1071's post wasn't there a minute ago :)
Edited by Nick on 6th Mar, 2006.
benfredjosh
Member #: 927
i thnk i'll have to i cant find the link now so maybe you guys could drop it to me? and does anyone know the all round cost of the kit and the wait you have for it tobe delivered?
benfredjosh
Member #: 927
brilliant i thnk i'll hav 2 save for a week of two! lol u knwo if u buy turbo pistons do u need a re-bore to take it to 1293cc? or is it a difference in the piston size? thanks guys for all ur help so far!
benfredjosh
Member #: 927
sorry I blame Msn for my Text Missfunctions !!! i blame msn for all my lifes problems!!
i am on a budget but i guess i'll have to wait and then eventually spend more? if that makes sense?
as i am in the process of buying a genuine mg metro 1275 engine and i think the best route for me to go down the turbo path would be to turbo the mg unit as it is a very good engine?! soit shouldnt give me many problems? fingers crossed? i am going to start ggathering the parts ASAP i need a website to get modified plenums so i can run an intercooler and dump valve at the same time if anyone knows any sites? or has one second hand,
i did put a wanted add up but i have recived no replies so maybe mini 1071s you could have a look at it and see if you have any of the spares i need? by the way do you think you could pm me yyour msn addy please as i'd like to pick your brains abit? thanks and sorry about the way i was writing! *happy*
Well you could just throw a turbo on a metro engine as long as it's not a MG high compression one or on its last legs! But you can only run 10psi with an I/C. Depends on what spec he wants?
Mirage have the manifolds in stock for immediate dispatch!
Edited by Bat on 7th Mar, 2006.
for the mirage, you just need a 2" mid pipe and tail pipe, as it already comes with a stainless downpipe to suit
