| Home > Help Needed / General Tech Chat > Clutch knackered (possibly) (none Turbo) | |||||||
397 Posts Member #: 694 Senior Member Shropshire |
6th Mar, 2006 at 05:05:22pm
Just attempted to start my MPI cooper however the clutch pedal is solid. The engine will start idle and I can put the gear stick into any gear however its not feeding the power to the gear box and therefore carries on idling. I am therefore assuming the clutch is knackered. Would anyone disagree with this?
6th Mar, 2006 at 05:13:23pm
the flywheel is different...
6th Mar, 2006 at 05:36:41pm
So the clutch is completely not driving - ie like your foot is on the pedal (but it isn't) ???
6th Mar, 2006 at 10:13:29pm
could be also the slave cylinder is siezed in the out position
6th Mar, 2006 at 10:29:34pm
Edited by Bat on 6th Mar, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
567 Posts Member #: 102 Post Whore Pennsylvania USA |
7th Mar, 2006 at 12:34:31am
I had a blockage in the pipe once. Pressed the pedal and the fluid wouldn't go back to the master cylinder keeping the clutch dissengaged. |
7th Mar, 2006 at 12:03:27pm
7th Mar, 2006 at 12:15:51pm
I've had exactly the same problem. It is (as has been said) most likely that the plinger is seised on the cover.
7th Mar, 2006 at 12:22:50pm
Thanks for all the information. It is very much appreciated.
7th Mar, 2006 at 10:28:10pm
