Home > Show Us Yours! > Shiney bits in the post
These turned up today. I'm not buying in any particular order *wink*
I'm, sure you know but for anyone elses benefit you need to make sure you thoroughly wash off the packing oil that ARP use, paraffin or another suitable solvent will do, then use the ARP supplied lube and torque settings.
I didn't know that Tom, learn something new every day.
same hear Jim, I've never washed any of the packing oil off parts, as long as the parts look clean on would go the.
looks good nice new brakes:)
Edited by Miniwilliams on 7th Mar, 2006.
is it the arp studs that require the head to have its stud holes chamferred or slightly countersunk?
or am i rehashing another mini myth?
can't speak for the arps, but it is a good idea to slightly countersunk your stud holes any way for what ever you use :)
its common practice on any surfac ethat has a bolt pulling on it with high torque loads, helps to p[ravent the top thread pulling up and distorting the gasket,
carl
Well the discs came about due to a disaster really! The N/S wheel bearing was fubar, so I got one to replace it, this is where it all goes horribly wrong :(
Jack up car, remove wheel, remove hub nut. Remove caliper, brake pad fell apart. Found hubnut cracked, CV thread stripped. So I went from bearing to cv + discs and pads.
Got the above, fitted CV, bearing, disc and caliper. Pistons won't go back into caliper :(
So Now I've got 2 new calipers as well!
This wheel bearing is getting very expensive! *surprised*
'Spose I can't grumble though, they've been on there 12 years!
Oh by the way, do you think £50 for the ARP was a good price? *wink*
Edited by Bat on 9th Mar, 2006.
