| Home > Help Needed / General Tech Chat > gearbox self rebuild | |||||||
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
10th Mar, 2006 at 08:08:47am
hi
10th Mar, 2006 at 08:51:41am
haynes manual is a good start
Edited by BENROSS on 10th Mar, 2006.
10th Mar, 2006 at 08:56:47am
which oil pick up should i buy to use? just i know i should get a central one but which ones best?
10th Mar, 2006 at 09:11:03am
cebtral ones best, also new baulk rings, lay shaft plus bearings.
10th Mar, 2006 at 09:30:10am
if i went the straight cut route what straight cuts should i buy? and what final drive? mines a rod gearbox!
10th Mar, 2006 at 11:58:23am
my mini is a 1982 998 hl! so ill have a look but is it a case of replace it with the same? |
10th Mar, 2006 at 12:03:24pm
Im planning to build up my next box myself.
10th Mar, 2006 at 12:09:44pm
On 10/03/2006 09:30:10 martpaul said:
if i went the straight cut route what straight cuts should i buy? and what final drive? mines a rod gearbox! thanks his thread might help you out: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7696 "Turbo's make torque, and torque makes fun"
10th Mar, 2006 at 12:14:45pm
cheers |
31 Posts Member #: 448 The name's Mystic. Graham Mystic. |
10th Mar, 2006 at 02:18:06pm
I would encourage you to replace every bearing in the case. You did not mention why you were doing the rebuild in the first place so is this just preventative maintenance? |
10th Mar, 2006 at 02:20:17pm
just im building a 998 turbo and so need to have a good conditioned box, n rebuilt! |
10th Mar, 2006 at 04:07:18pm
the minispares clubman gearset is excellent paul
11th Mar, 2006 at 08:10:13am
make sure its very clean before putting in the oven other wise you will stink out the kitchen lol. always looking for them bigger bunches of bannanas |
