| Home > General Chat > Pipe reducer | |||||||
10th Apr, 2006 at 12:18:05pm
As we all know, the pipe to the pressure regulator needs to be 5/16, and the outlet from the plenum is 1/4.
10th Apr, 2006 at 12:22:04pm
I beleive T3tone has one and as we have seen in the mag, alls running very well. Best 1/4 mile 13.2 seconds @116 mph
10th Apr, 2006 at 01:06:23pm
that looks handy, would it do any harm fitting it between the reg and carb on the fuel supply? i had some right grief getting 8mm pipe to clamp down onto the 6mm carb unions. On 20th Oct, 2015 Tom Fenton said:
10th Apr, 2006 at 04:27:13pm
I use reducers on both lines (reg-fuel supply and plenum-reg). No problemos. -MINI CLUBMAN 1380 TURBO- |
10th Apr, 2006 at 04:34:11pm
I used pipe to suit the smaller pipe stub, and then stretched the other end enough to be a snug fit on the larger tails of the fuel regulator.
10th Apr, 2006 at 04:35:26pm
I've always got the 1/4" EFI spec fuel hose onto the 8mm outlets on the regulator pretty easilly... I have outlined the technique previously - maybe someone can find it with a search?
10th Apr, 2006 at 04:37:09pm
and think about the weight!! Weight is Evil! On 15th May, 2009 TurboDave said:
10th Apr, 2006 at 05:06:04pm
On 04/12/2005 22:25:22 TurboDave said:
6mm fuel injection hose. Immerse in boiling water for a few minutes. Whilst doing that, get a 'heel bar' and hold it in your vise, taper upwards. Grease the taper. Bring hose out of boiling water, and ram, slide, push, twist, etc onto the taper. Let cool. Slide off taper, immerse in boilling water again. Ram, slide, push, twist, etc onto taper, then pull off taper and simply 'pop' it onto the regulator pipes (yes, it really does just pop on there). You should really be using EFI hose here - which is usually harder to 'work' than lower grade stuff; hence why I adopted the above technique. Easy ![]() FROM: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6994 This is what a heel bar looks like: http://www.machinemart.co.uk/images/produc...MM040210272.jpg Available from anywhere that sells tools. Sometimes incorrectly called a 'pry bar'... Edited by turbodave16v on 10th Apr, 2006. On 17th Nov, 2014 Tom Fenton said:
10th Apr, 2006 at 05:07:00pm
jim-SHHHHHH
10th Apr, 2006 at 05:25:42pm
yeah i remember dave posting that a while ago, its just one of those jobs that gets pushed to the bottom of the list all the time. On 20th Oct, 2015 Tom Fenton said:
10th Apr, 2006 at 11:22:58pm
On 10/04/2006 16:37:09 Jimster said:
and think about the weight!! Weight is Evil! Trust you to think of that jim! Best 1/4 mile 13.2 seconds @116 mph
11th Apr, 2006 at 06:50:11am
i just made one out of brass on my lathe it works a treat, 8mm one end 6mm the other.
13th Apr, 2006 at 03:10:34pm
http://cgi.ebay.co.uk/FUEL-HOSE-METAL-JOIN...1QQcmdZViewItem
13th Apr, 2006 at 10:28:01pm
On 10/04/2006 16:34:11 Tom Fenton said:
With a combination of a pot full of boiling hot water and a tapered bar it is not that hard to stretch i long nose pliers,stick both jaws in and pull the handles apart
