| Home > Help Needed / General Tech Chat > Need some advice about rust | |||||||
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
18th Apr, 2006 at 11:56:37pm
This ones a bit lengthy...
Edited by andeh on 18th Apr, 2006. I've seen the future and tbh its Pie
18th Apr, 2006 at 11:59:37pm
Worth noting that before this point the car was neglected by myself, being a daily without having much attention in the maintenance side of things (appart from bling go faster bits), but its now a garaged second car which i dont plan on using much. Edited by andeh on 19th Apr, 2006. I've seen the future and tbh its Pie
19th Apr, 2006 at 12:12:05am
19th Apr, 2006 at 01:52:06am
Just repair the lot now and take a little time to get it right first time. I am now at the start of mine, car being dropped off at my mum and dads garage on thursday (Engine out sunday) Got to get this right, cos as mini1071s says, its an investment in this day and age of ever rising prices to what can honestly be described as stupid. Not to mention the shell flopping about like a dead fish wrapped in newspaper.
Edited by Sprocket on 19th Apr, 2006. On 26th Oct, 2004 TurboDave16v said:
19th Apr, 2006 at 11:12:02am
sounds unanimous, I’ve been itching to do it as well as its one of the only parts of the car im not happy with. However, what am i likely to need to do the job panel wise? Its not going to be just outer sills, so what else is it a good idea to get ordered at the same time? Inner sills? floor patches? Door step?
19th Apr, 2006 at 11:21:44am
To do a proper job of replacing the floors, I'd say your best bet might be full length floorpans? You can then weld the proper outer sill to this and have a strong joint. However to do these well it really wants both the subframes off the car etc etc, so it depends quite how far you want to go with it?
19th Apr, 2006 at 12:27:09pm
the whole of the front is already off the car, its not going to take much to take the rear subby off in all fairness, i was thinking of doing it anyway. Thing that comes in is the cost of a full length floor which'll be £230 or close. I've seen the future and tbh its Pie
19th Apr, 2006 at 02:10:53pm
Decided im gonne take the outer sill off this side regardless to do an investigation, are things gonne go all wobbly when i do this? I.e anything i need to look out for?
20th Apr, 2006 at 01:11:21am
tack weld in cross braces made of flat bad at the door aperatures and if removing any large quantity of flooring in one go another cross brace across B post to B post, this should minimise any distortion. Its also worth using some wood batton across the floor pan between each corner of the floor and support the body on axle stands that way.
