| Home > Help Needed / General Tech Chat > Broken Spark Plug--Why? | |||||||
55 Posts Member #: 909 Advanced Member |
19th Apr, 2006 at 05:31:13am
I've finally installed a used metro turbo lump I bought as an assembled unit. It runs, but at idle there's a steady build-up of blue smoke and I was having an unsteady idle. I've found a vacuum leak at the inlet manifold where I plumbed in the vacuum/boost gauge and the blow-off valve (red alloy--already installed on plenum).
19th Apr, 2006 at 06:52:50am
spank ,this is often caused by detonation ,i have some plgs from a car ,that had no centre electrode or side or porcelain!! check mixture ,and timing,and use the highest octane you can ,eg optimax or that tesco 99 i think its called ,also try runnig a b7 plug instead of a b6 .oh and check the timing at 3500 with the vacuum advance off to see you total timing ,regards robert. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Apr, 2006 at 07:43:16am
Could be detonation. I'd be tempted to change to the 7ES plugs rather than the 6ES to start with. Then, as you don't know the setup of the car, get it rolling roaded. this could save you melting a piston rather than a spark plug next time.
19th Apr, 2006 at 11:26:47am
i won these the other day, bargain i thought:
19th Apr, 2006 at 11:33:00am
bollocks..why didnt i think to look on ebay for cheap plugs. i end up paying £16 a set in halfrauds for the bpr7es's On 20th Oct, 2015 Tom Fenton said:
19th Apr, 2006 at 02:47:04pm
I'm in the US. A "rolling road" would cost $350 US minimum, or about 160 GBP and it's not like they are on every corner here.
19th Apr, 2006 at 03:02:51pm
mine was eating spark plugs until I done the T peice trick and blocked the vent valve
19th Apr, 2006 at 11:15:43pm
