| Home > Help Needed / General Tech Chat > megajolt problems! | |||||||
255 Posts Member #: 520 Senior Member nr hull |
1st May, 2006 at 07:50:36pm
hey up all,
doh! why did i start messing with it!
1st May, 2006 at 07:57:04pm
I haven't done this yet, but if you are knocking up tacho drivers Pete I would also be interested in one.
1st May, 2006 at 08:05:05pm
i connected my tacho up to me EDIS module and it works fine. i must be lucky. so id try yours first tom. no longer a series, but still 1.3 turbo.
1st May, 2006 at 08:10:31pm
oh that'd be great pete! anyone got any ideas on the problems with the switchable outputs? doh! why did i start messing with it!
1st May, 2006 at 09:10:18pm
yes please pete :) "Turbo's make torque, and torque makes fun"
1st May, 2006 at 09:17:28pm
Many tachometers can accept the 12V signal emitted from the MJLJ module. however, some OEM tachs detect the RPM signal by sensing the high voltage flyback pulse from the ignition coil. In distributor based setups, there is only one ignition coil to detect this pulse from. With a wasted spark system like the Ford EDIS, you will have multiple coils providing this signal. Consequently you may need a way to detect this pulse across multiple coil-packs.
AlexF |
1300 Posts Member #: 829 Post Whore essex |
1st May, 2006 at 09:24:27pm
Edited by jimmy on 1st May, 2006. 1293 Turbo mini
1st May, 2006 at 11:19:22pm
On 01/05/2006 21:17:28 AlexF2003 said:
isnt that for a car running 2 coil packs (v6 or similar) so for our purposes, using a single coil pack, would just the zenner do, or would you still need the diode? must get round to sorting mine out, its a tim one too, and that wouldnt run off the edis module or megajolt output |
1st May, 2006 at 11:23:33pm
The ford edis coil is two coils in one coil pack so you need the diodes 1293 Turbo mini
2nd May, 2006 at 05:56:28pm
lol i'll defo have one please peter, i can just about manage to get a little solder on a wire or two and give myself 3rd degree burns but thats about my limit with a soldering iron!
Edited by hippyinamini on 2nd May, 2006. doh! why did i start messing with it!
2nd May, 2006 at 06:03:35pm
peter can i be put down too, ive the feeling ill end up with a bold patch on my head from head scratching |
2nd May, 2006 at 06:22:36pm
On the same subject,I have a tacho off a 4 stroke single cylinder motorbike-Has 3 wire pos/neg and green pulse.
2nd May, 2006 at 06:32:54pm
I think it will not work because it is a single trigger per cycle were the mini is four per cycle 1293 Turbo mini
2nd May, 2006 at 07:35:03pm
2nd May, 2006 at 08:09:10pm
On 02/05/2006 18:13:48 mini1071s said:
AlexF, maybe you could put one in your range of goodies? Most people seem to like their old school tachos. You would sells tons on ebay. I'll get on it :) Alex AlexF |
2nd May, 2006 at 08:31:24pm
Please can i buy one too Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
2nd May, 2006 at 08:40:17pm
me too:) |
3rd May, 2006 at 07:53:27am
the Y lead would be good, for me at least! |
3rd May, 2006 at 02:49:10pm
Yes, Y lead fine for me also.
3rd May, 2006 at 05:18:57pm
nice one! |
3rd May, 2006 at 05:58:53pm
lol sounds good to me! doh! why did i start messing with it!
3rd May, 2006 at 07:01:05pm
3rd May, 2006 at 10:51:22pm
argh my heads hurting now, right update... turns out the megajolt aint working atall, it links up to the computer ok but isn't actualy working the engine. i finaly found my old timing light and tested it to see if it advanced and not a sausage, tried testing if it altered when the information was changed and nowt, finaly took it off and ran on edis and it was the same so its been running on default all this time, the thing that threw me was its a few deg more advanced than it should be, hence it running well enough to drive and going like a scalded cat on turbo but bogging down off it.
4th May, 2006 at 12:13:48am
Steve
4th May, 2006 at 12:16:15am
http://www.bgsoflex.com/mjl/mjl_edis_summary.html
