| Home > Help Needed / General Tech Chat > megajolt timing? | |||||||
10th May, 2006 at 05:22:19pm
im running megajolt with one of toms pulleys sensor set at 9.00 oclock if missing tooths at 12 ocock. ive done over 500 miles upto now this week. ive set my ignition timing to 23 degrees fixed throughout the whole range thinking this will be safe for running in.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
10th May, 2006 at 05:43:28pm
the tacho on the gun is indeed because of the wasted spark system..... cant help with the 45degs tho.....
And on the 7th day........... God created turbochargers! |
10th May, 2006 at 05:58:44pm
well if the tachos double then does that mean the advance must be double? ive just rechecked it and its more 46 degrees than 45.
10th May, 2006 at 06:03:28pm
not sure...... but if youre not right, its one heluva coincidence....... only just got mine running last weekend, so still not completley up to speed to be honest.... And on the 7th day........... God created turbochargers! |
244 Posts Member #: 34 Senior Member |
10th May, 2006 at 06:23:20pm
Disconnect your mega jolt, and start the car with just the edis.
Edited by Gibbo on 10th May, 2006. |
10th May, 2006 at 06:44:16pm
You gun is counted two sparks when it thinks there will be 1
AlexF |
255 Posts Member #: 520 Senior Member nr hull |
10th May, 2006 at 06:50:58pm
bollocks does that count for all timing guns? would sort of expalin some strange figures ive been getting! when checking the jolt against the pully. ive been thinking its 9 deg too advanced so ive retarded the jolt as much to be safe!
doh! why did i start messing with it!
10th May, 2006 at 07:25:35pm
I don't see how it will affect the basic strobe function of the gun. If you connect it to plug one then it will fire at TDC for cylinder 1 and 4. The missing tooth will be in the same place for both cylinders. If you have a fancy gun ignore that and just read the timing marks on the fly wheel or timing wheel with the strobe. It should be fine.
http://www.twin-turbo.co.uk
10th May, 2006 at 07:48:06pm
just been out and dissconected mjlj and with my gun it says 20 degrees. if it were 10 degrees out then when i set it to 23 degrees it would be 33 degrees not 46 degrees so im gonna go with the wasted spark thingy threory.
Edited by Carl on 10th May, 2006. no longer a series, but still 1.3 turbo.
10th May, 2006 at 10:11:46pm
On 10/05/2006 19:48:06 Carl said:
just been out and dissconected mjlj and with my gun it says 20 degrees. if it were 10 degrees out then when i set it to 23 degrees it would be 33 degrees not 46 degrees so im gonna go with the wasted spark thingy threory. sorry if what ive just wrote makes no sense im using a snap on timing light but is an older model. Bingo! Its because the plugs are fired in pairs... and all the Timing Gun does detect the magnetic field the electricity passing down the HT lead creates. As a HT pulse happens twice as often in Wasted Spark than a single coil system this upsets the counting and hence flashing the timing light does. However, some timing lights do not seem to mind. Either way you should still be able to use the marks on the pulley and timing chain cover. Alex AlexF |
12th May, 2006 at 05:12:27pm
