Home > Help Needed / General Tech Chat > Inlet charge temps
Nick
Member #: 154
Midlands
got myself a temp gauge in my IC piping after the IC working in a fashion now, just wondered what sort of temps are good?
on the motorway on the way to newquay at night i was seeing around 11 degrees C, round town its usually around 28 degrees. The worst bit is starting it back up after a run and seeing how bad the heat soak is, highest i've seen so far is 50 degrees.
Be interesting to see what the temp going in to the cooler is. but anything below 30 deg is good
Nick
Member #: 154
Midlands
yeah i wanted to put a pre-cooler one in but apparently these gauges i've got are only good for up to 70degrees so was unsure of em...
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Anything over 45 degrees C and you need to start retarding the timing.
Of course the other effect is the one of air density and your Air/Fuel ratio.
Alex
AlexF
Nick
Member #: 154
Midlands
cool, cheers alex. just wondered what sort of temp to watch out for :)
turbo hogster
Member #: 178
stowmaket suffolk
dont boot it or lift off after about 45 - 50 deg thats what i do.
I don't know if the MJ has this option, but on mine I can retard the timing in relation to the air (or engine) temp.
It may well be worth looking into this and setting it up, cheap way to reduce the possiblity of engine damage *wink*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
no but you can map it in *wink*
Alex
AlexF
Just as good!
