| Home > Help Needed / General Tech Chat > In Car Boost Control | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
16th May, 2006 at 11:57:18pm
What sort of boost should i be looking at running all the time on my 1275 that is safe and is it possible to up the boost when i want it bearing in mind i'm running standard pistons but have an oil cooler inter cooler and 4 core rad to keep the engine cool
17th May, 2006 at 12:02:06am
About 20 psi asuming you run very good high octane fuel and the intercooler is very efficient, depending on compression ratio and quiality of build.
17th May, 2006 at 11:13:29pm
You crazy wouldn't 20psi melt standard pistons i was thinking about 8psi and when you need it 12psi i'm on 5psi at the mo and to be far my standard 1275 could blow my turbo out the water so i need to do some cause surely thats not right |
17th May, 2006 at 11:28:21pm
Jon's comment was "tongue in cheek"... He's basically saying - you run whatever your engine will LET you run...
Edited by turbodave16v on 17th May, 2006. On 17th Nov, 2014 Tom Fenton said:
18th May, 2006 at 11:45:51pm
Thanks for the advice Dave! The bit i could understand ratios and all that make head spin. Whats is it a case of putting it on a rolling road or just playing round uping the boost i surpose it will get to a point where you've over boosting and reached the engines peak but i'm a bit scared on where cos the lad i brought it off blow his engine up driving it round on 15 - 16psi so just looking for some simple tips aprt from not booting it round all the time and running on full boost. Just like i say after a bit for performance cos its slow to be far and staring to think was it worth al the work but am worried about standard pistons heard enough scary tales on here about them |
19th May, 2006 at 12:43:09am
Thanks Dave....
19th May, 2006 at 09:52:14am
right thanks for the advice anyway lads any website you reckon are worth a look |
19th May, 2006 at 02:47:13pm
yeah this one! lol!
20th May, 2006 at 12:51:58am
i have standard 1275 turbo pistons and run my motor to 12 & 15 issh..... COUGH ! psi of boost on my so called budget motor
20th May, 2006 at 11:45:28am
And ive witnessed how fast and well it runs Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
22nd May, 2006 at 11:10:26pm
i was thinking about 10psi but i'll put it on 9psi i see if it can see off my standard 1275 lol but i do think theres other reasons like the weight diffenerce and i swear lossing power though the intercooler and dump valve like all the distance the air has to travel to intercooler and the dump valve not like any other cars dump valve leaking air all the time can't be saving you power |
23rd May, 2006 at 10:00:02am
24th May, 2006 at 10:09:53am
Sorry came out worng not leaking cos i had a diafram one and that was and i got that feed up with it i chucked it and got myself piston type never looked back since but i was talking about the way the dump valve is open all the time must be lossing power though that any one got thoughts on that? are these turbos faster with or without |
24th May, 2006 at 10:20:13am
you dump will only be open on vacuum, it should be closed on boost then open when you lift off....have you plumbed it in properly? On 20th Oct, 2015 Tom Fenton said:
