| Home > Help Needed / General Tech Chat > piston choices! | |||||||
23rd May, 2006 at 12:31:23am
Ello everyone, have used the search function and looked at many different specs and seen quite a variation in choices of pistons!
23rd May, 2006 at 02:08:40am
Well - the omegas are lighter I believe - but the MEGA are available (easilly) individually, from any of the minispares locations.
Edited by turbodave16v on 17th Nov, 2008. On 17th Nov, 2014 Tom Fenton said:
23rd May, 2006 at 09:04:16am
i would say 15 psi is a ideal max level for every day car, that would mean about 8 psi for your normal boost level. using this method then you can see what cr you need, i would say around 8.8 to 1 would be ideal, you dont want to go to low cr if you are not going to run shed loads of boost as i will just eneding up going backwards before you go forwards if you get my drift.
24th May, 2006 at 12:35:14am
Thanks for the info guys! Really helpfull! I think im going to get the omega's from MED |
