Home > Help Needed / General Tech Chat > heater hoses
TURBO ME
Member #: 772
new york
i did a search but could not find it but i think i've seen it on here before anyway ....
if i connected block heater takeoff hose to top radiator hose and
blocked off bottom heater takeoff on bottom radiator hose
would this help with lowering cooling temps.
It will if your rad is upto it. If you've got the room put a heater matrix behind the grill and pipe it up as you would a heater *wink*
This will take some the load off the main rad....
Flush out cooling system, and refil with fresh water / antifreeze mix. The anti freeze helps with cooling *surprised*
