Home > General Chat > Roof linings
Brocky
Member #: 224
Katy TEXAS
Hello everybody
Does anyone have any tips on refitting roof linings?
It seems to have shrunk...
Brocky
giallofly
Member #: 164
The Stig..
Newport Pagnell
Get down WH Smiths for some little bulldog clips to hold it up while you glue it...
Take your time.
Dicanio
Member #: 91
As jon says, bulldog clips are a must, start at the front then the back, do the sides last.
If you can't afford/be bothered using bulldog clips, chop some small {2"} pieces of window seal up and use these to hold it tin place.
Phil. *smiley*
I prefer the tiny buldog clips as these allow you to get round the corners more easilly, and pull the lining easier. Buy at least 50 - ideally 60 of them.
Re the linings, I've done four now.... And only now can i say I'm getting good at them. They're reasonable easy to get alright, but very difficult to get perfect. I spend around 12 hours over three evenings on the last one!
You need a hairdryer to heat the lining around the outer 9/12", which allows you to pull it REALLY tight.
That said - sounds like you're using an old one, so it should be a doddle!
Edited by turbodave16v on 15th Jun, 2006.
Brocky
Member #: 224
Katy TEXAS
Thanks guys,
Will yet you know how I get on
