| Home > Beginners Tech > Timing | |||||||
43 Posts Member #: 191 Member Falkirk, Scotland. |
25th May, 2006 at 07:06:37pm
Having a bit of a problem getting the timing set up. If I set it as per the book at 7deg BTDC, the engine doesn't run too well. If I advance (?) the timing to around 16deg BTDC it runs a lot smoother. Should I set it as per the book and look around for other problems or just accept that it runs ok at 16deg?--I'm running the Metro Turbo electronic ignition system. |
25th May, 2006 at 07:12:25pm
Are you setting it to 8 degrees with the vac advance disconnected??
25th May, 2006 at 10:49:19pm
yup.. |
27th May, 2006 at 04:11:20pm
Is the engine standard? -MINI CLUBMAN 1380 TURBO- |
27th May, 2006 at 06:26:02pm
when you set the timing are you runnig the engine at the correct speed for the timing gun?
28th May, 2006 at 02:05:57pm
The only thing that I have some doubt about is the coil- this is not the original. Everything else is as fitted to a Mark1 (?)-1983- Metro Turbo. ie remote Ignition Amplifier etc. Timing is being set with the Vac Advance disconnected and the engine running about 850rpm. Would the wrong coil make a big difference to the running?? |
28th May, 2006 at 03:14:14pm
28th May, 2006 at 04:45:37pm
thanks to all who replied. Will check out basics and see if that sorts out problem. :$ |
28th May, 2006 at 06:08:52pm
The timing should be checked at 1500 rpm, with the vacuum disconnected, as others have mentioned. |
