Home > Technical Chat > Why place the dump valve close to the throttle?
I've been trying to get my head round this for a while but it seems beyond the ability of my little sparky brain.
From everything I've heard you want to place the dump valve as close to the throttle as possible (most people including myself have them on modified plenum chambers & even Rover put the pressure release valve on the plenum) however the roll of a dump valve is to stop the turbo from stalling due to back pressure created when you snap the throttle shut (changing gear, breaking, etc) Now the way I see it is that surely you'd be better off trying to release the excess air pressure as close to the compressor wheel as possible as it's the turbo which you are trying to protect.
I'm quite happy to accept I've got something wrong as what seems like the sensible option to me is the opposite of what every & his dog are doing, but could someone please explain the reason why you put the dump valve as close to the throttle as possible (and as far away from the turbo as possible for that matter)
i thought it was due to the way the dump valve works, i.e on the pressure differential between the inlet and the plenum.
if you put the dump valve near the turbo, it might always have a higher pressure than the inlet (especially if you run an IC), so might continually vent when on boost.
Again, no experience of this, just regurgitating what i have heard somewhere along the line...
Also, and im most probably wrong about this one, but releasing pressure is releasing pressure, no matter where you do it from the same system (im sure the location of the dv will ever so slightly effect the efficiency of the 'local' pressure drop, but it probably would make neglible difference in our case...???
TBH, I dont think it makes any odds....
Some would say after the IC, as you are plessing less heat loads on the DV.
Others say close to teh turbo, which is placing much higher heat loads on the DV.
Some say close to the throttle....
The heat issue is possibly relevant to DV life, as some DV's are pretty crap.
But I really dont think it would make pick of difference where it is located within the system, in terms of ability to release air when required.
Valid point, but if you have that much of a pressure difference across your IC, you really need to address that too.
Most DV's should be fairly strong, and cope with such differences. If they dont, then I wouldnt be using them regardless.
As I mentioned in another thread, some of these HKS and Blitz DV's are a joke. I was working at a Subaru the other night with a HKS SSQ DV, fully adjusted so it was as tight as it could be. Yet on boost....you continually heard it venting air.
Slapped a Bailey in its place, and it was fixed.
Dangerous
Member #: 417
When the butterfly closes it makes a dead end,If you put the d/v further away from the dead end, then the pressure will have to return back down to the d/v
Thats my verdict
I think it has a lot to do with the inertia of the air.
When the throttle closes, you have both pressure and inertia to deal with. With the velocity involved the inertia is probably as potentially damaging as the pressure.
The only way to vent the inertia is with the dump valve as close to the butterfly as possible.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
As far as I understand it a combination of the last two posts is the actual answer, that along with trying to keep the signal line as short as possible (I know we are only walking a few microseconds difference with the speed of sound in air but .....)
Thats my verdict
No it wont.
That air will stay where it is, and any air following behind it, will exit the DV.
Same with water. If you have a hosepipe thats closed at one end ( or running then closed ), and you cut it half way along ( ie open a DV ). water at the front of the pipe doesnt suddenly do a u-turn and try and exit. It just stays there, and any water following behind exits.
Or, drive a car with no windscreen. Eventually, air pressure will build up inside the car, and create an invisible wall, so any further air, will travel around this wall.
It'll still be damn cold though !!!
Edited by stevieturbo on 3rd Feb, 2007.
RogerM
Member #: 1217
Steve, that is a good analogy with the hose pipe. I was trying to think of one that wouldn't sound insulting and also put things simply.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I know that air and water are both fluids but isn't there still a bit of difference? Like would air not be way more compressable than water? Meaning air might not actually be flowing but pressure could be higher at the back of a closed butterfly that further back towards the turbo for that split second after the throttle is shut before it would equalise out?
On 7th Nov, 2008 Nic said:
naeJ
m
It is compressible of course, but it will make no odds.
If we are getting that fussy, mount one at the Throttle, and one directly at the compressor outlet.
I think it's to do with reducing "lag"
If you put the DV right by the comp when you open the throttle again, as in changing gear the turbo has to pressurise the entire intake system again.
Whereas with the DV close to the butterfly the system is still partially pressurised.
Seriously, you will not noitce any difference in lag, whether its mounted at the TB, or the Compressor.
In fact, try not using one at all, and see if you notice a difference.
The biggest difference a DV made on my car, was it made part throttle a lot smoother.
t3gav
Member #: 229
Gavin@minispares.com
kent
Good post this, i thought everyone knew lol, i can see where bat is coming from.
I notice a difference on my cossie without the DV. Turbo makes a horrible growling noise when changing gear!
I've noticed on OE DV installations they can be on the hot or cold side, but I can't say as I've seen any right by the compressor or right by the butterfly..... Someone will come along now and "educate" me!
Like with most things in tuning there's a lot of BS spouted, so much in fact it's hard to tell what's right! *wink*
Edited by Bat on 3rd Feb, 2007.
It may make a different noise....but does performance change ?? I suspect not.
In most cases, a DV will make no noticeable difference to performance. Not all, but an awful lot, especially low boost setups.
As for BS, you are so right. the only right answer, is to fit the DV, wherever is easiest.
Cheers guys, there some interesting food for thought there.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
The DV will not help performance!
If you want to make it quicker loose the DV and go the boost spike as you change gear *happy*
Alex
AlexF
Of course, if you neer lift your foot off the accelerator, you will never need a dump valve lol.....
Flat shifting anyone ? IF you run MS, then surely you can hook up a flat shift ign cut.
Stevie you're right, it would be a waste of money if you were fitting one for a performance gain.
But then I guess a blown to bits turbo is going to make a drastic reduction in performance *wink*
Leonard
Member #: 806
Cirencester, Gloucestershire
isnt the cosworth dv take off on the intercooler itself?
Jay#2
Member #: 648
I thought a DV on something as small as a mini increases lag? I.e. if it vents completely the turbo has to rebuild the boost?
naeJ
m
Show me a turbo that has failed because of not having a dump valve fitted....then I'll believe you.
I know some modern Subaru IHI based units can be fragile, so a DV can be of beneift there. But Ive seen plenty of them fail with DV's fitted too ( although they all have a DV anyway, you get some people removing them though. )
Ive built and run plenty of turbocharged engines over the years. Some have had dump valves, a lot havent. Ive never had a turbo failure I could attribute to lack of DV.
In theory, it venting boost on closed throttle, should help keep the turbo spinning, so it should spool up again faster when you open the throttle again.
In reality, it makes virtually no difference whatsoever.
turbo hogster
Member #: 178
stowmaket suffolk
from what ive been told and have found out is that a dump does only one thing and that is sound good.
mine went better when it was stuck closed through the gears.
all i do is when going down the strip is to wind it in a few clicks.
andybod
Member #: 1476
the theory behind the dump valve is to stop the turbo stalling between geachanges thus helping it to spool up faster but a dump valve doesn,t become efective until a turbo is running at around one bar approx14 psi so as for running 4-7 psi a dumo valve isn't really necessary but an still sound great
