Home > Wanted > carb heat shield
steve1275
Member #: 951
Bromsgrove
Does anyone have a spare they will part with for some cash?
'Where does the engine go?'
I think Nogin on here was going to make some, don't know how far he's got with it?
steve1275
Member #: 951
Bromsgrove
Thanks Gavin,I have an order in with Nogin,but meantime I want to run the beast!
I'm sure people on here run their motors without. It just makes hot starting harder!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Quite handy having a shield there...especially if you have a Carb fuel leak! had petrol coming in through the bulkhead! :(
Edited by Jason G on 2nd Apr, 2007.
On 19th Jan, 2010 wil_h said:
nogin
Member #: 487
westbury, wiltshire
guna be making a few up in the next week or two as have tested one on mine and all is good, just need to order some more fibreglass
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I can do some ally ones if required.
steve1275
Member #: 951
Bromsgrove
PM sent
nogin
Member #: 487
westbury, wiltshire
i thought about ally ones but the problem being is the heat issue, ally keeps heat quite well and absorbes it very well, if you made them in stainless stell then thats a different matter, thats why rover chose fibreglass as it doesnt conduct heat very well, just my thought
i also make things
Jason G
Member #: 1459
En-suite user
Braintree, Essex
good point nogin...but fibreplass doesn't reflect heat too good. Stainless is better...depends on the application. Bright annealed steel is good too, but will rust over time
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Can do one in stainless...will send you drawing steve1275
steve1275
Member #: 951
Bromsgrove
Anyone tried using heat resistant material stuck to the shield?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I've quickly made one out of mildsteel. It bolts on the plenum.
Any opinion welcome.......... *wink*
Will make them out of ally or stainless (if I can find off cuts!)
Edited by Jason G on 17th Apr, 2007.
Star Mag
Member #: 375
Leicestershire
I run my mini without the sheild as i have got a complete one! The only problem is it takes a few secounds more to start!
nogin
Member #: 487
westbury, wiltshire
still testing mine and waiting on iain to do a rr session on the one i sent him, but i can feel a real difference on the one i have, cant touch the bottom but the inside is still pretty cool
i also make things
Jason G
Member #: 1459
En-suite user
Braintree, Essex
cheers nogin....steve came up with a good point. Making it so it bolts to the manifold to stop it moving.
I shall do a modified one for myself or anyone with the float spacer.
Post a pic nogin...be interesting to see m8
JT
Member #: 637
Hertfordshire
yer im planing on using a plenum from nic and im not sure if it has the same bolts as the standerd type?
one that goes on the manifold would be good.
My build thread..
Jason G
Member #: 1459
En-suite user
Braintree, Essex
A couple people said about supporting the front of the shield. Heres a newer version, any comments please.......
JT
Member #: 637
Hertfordshire
what does it bolt to? pelenum and manifold?
looks good
My build thread..
Jason G
Member #: 1459
En-suite user
Braintree, Essex
yes m8. Got another mod to do, just tried it on my metro. Making it abit wider. 3rd time lucky!!!!!!!!!!
Problably put some blanket in there to.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
That looks much better supported Jason.
Nogin, still like the idea of the composite one your doing ... keep us posted.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Perfected them today. Hope to get a couple made soon. Found some stainless. Natural, un-polished finish.
Heres some pics of my 'MKIII' prototype version (crappy zinc coated).....if anyone interested in a stainless one, let me know. *wink*
Edited by Jason G on 26th Apr, 2007.
nogin
Member #: 487
westbury, wiltshire
but do you know if they make a difference to the heat issue or not ?
i also make things
Jason G
Member #: 1459
En-suite user
Braintree, Essex
yep. Noticed similar things on metro cup cars & manifold wrap. I have a bulkhead one already fitted....but theres no protection against the exhaust. I will be ripping that out and putting one of my new heatshields on.
Try out one of yours if you like nogin, in race conditions should be a good test m8. :)
AL
Member #: 1347
Croydon (South London)
makes getting to those nuts even more fun *frown*
