| Home > Technical Chat > Why would you supercharge when you can turbocharge?? | |||||||
58 Posts Member #: 1724 PRIZE WANKER. |
16th May, 2007 at 12:30:57pm
Why would you supercharge when you can turbocharge?? .. Been looking at Members' ace photos and see that quite a few of you guys run superchargers ...WHY?
16th May, 2007 at 01:00:01pm
its all about lag. some hate it and some of us love it (dont like too much though)
16th May, 2007 at 01:06:09pm
On 16th of May, 2007 at 01:00pm Turbo Shed said:
its all about lag. some hate it and some of us love it (dont like too much though) turbos give you that punch in the back What you need then is Matti Alamaki's old rallycross Lancia Delta Integrale .. with BOTH !! :):) Edited by ppj_racing on 16th May, 2007. |
16th May, 2007 at 01:35:17pm
the man that built my engine used to work for Lancia and preped the 037's etc. he also worked on Will Gollops turbo 6R4 metro |
16th May, 2007 at 01:50:21pm
On 16th of May, 2007 at 12:30pm ppj_racing said:
Only the turbocharger gives you owt fer nowt ..by using waste exhaust energy .. while a supercharger uses some engine power very, very incorrect. A turbocharger uses a significant amount of energy to drive it - sure - a lot of this energy is from the heat contained inside the exhaust gasses, but the turbine is a significant restriction in the exhaust flow. It is difficult to quantify exactly how much energy is from the heat, but if you condier these 'rear turbo' setups witht he turbo many feet away from the exahust valve still make beans when they want to, it's not difficult to guess that most of their energy is from the exhaust gas velocity. A supercharger energy consumption on the other hand is easy to measure on a simple dyno. On 17th Nov, 2014 Tom Fenton said:
16th May, 2007 at 02:06:45pm
surely it must be fairly easy to measure what losses a turbo gives?
16th May, 2007 at 02:12:09pm
I've heard the free power argument before and though durrr?. No such thing as owt for nowt (perpetual motion ring any bells?)
16th May, 2007 at 02:15:20pm
Run 2 engines with one running NA but with a turbo boosting the other engine. On 7th Nov, 2008 Nic said:
16th May, 2007 at 02:18:57pm
you could still produce the boost though wil... just not use it.
16th May, 2007 at 02:24:54pm
got this idea in my head now... best talk to uni!! |
16th May, 2007 at 02:27:02pm
I just thought dyno an NA engine on an engine dyno then put on the turbo and the other engine will just take the boost and load the turbo, it doesn't matter what spec/power it is, it's there to take boost. On 7th Nov, 2008 Nic said:
16th May, 2007 at 02:30:59pm
ah as in use the boost on an engine at the side...
16th May, 2007 at 02:38:06pm
Yes, I don't think that you need two engines. I was just thinking of a dummy load i.e. a restrictor. If the compressor has nothing to restrict its output then you won't create a realistic backpressure.
16th May, 2007 at 03:20:13pm
But won't you need a throttle butterfly, carb, manifold etc (even the whole engine) to get the true restriction? I don't think you'd load the turbo with just the plenum. Edited by Jay#2 on 16th May, 2007. On 7th Nov, 2008 Nic said:
16th May, 2007 at 03:24:35pm
Not really, you could derive a dummy load that would be close enough to give good results.
16th May, 2007 at 04:36:51pm
end if the day you want it balls to the wall, so the butterfly etc will be wide open.
16th May, 2007 at 06:14:15pm
Im surprised nobody has considered using a centrifugal supercharger on a Mini yet....
Edited by stevieturbo on 16th May, 2007. 9.85 @ 145mph
197 Posts Member #: 1488 Advanced Member Bristol |
16th May, 2007 at 07:16:34pm
Just do what I think Axel was doing... use both! Turbo feeding a super. I might be tempted by a similar set up, depending on the finances when I get to building the engine. There is no sense crying over every mistake- you just keep on trying til you run out of cake. |
16th May, 2007 at 07:27:06pm
do you realy need both? when you can gget 200bhp woth turbos??
My build thread..
16th May, 2007 at 07:30:19pm
16th May, 2007 at 08:20:35pm
On 16th of May, 2007 at 06:14pm stevieturbo said:
Im surprised nobody has considered using a centrifugal supercharger on a Mini yet.... A small Rotrex unit would probably work extremely well. You wont get that huge rush of torque low down, but you will get massive gains up top. Think traction and drivability.
Turbos are superb, but when trying to achieve big numbers, which is easy...it often comes with a downside, especially on small engines, which is that massive step between on, and off boost creating a huge difference in power/torque. And the torque breaking things. Rotrex on an a-series mini has already been done, chap up this way had one built by GMC motorsport. im sure there was a thread on it at some point on here too. love the rotrex units :) turbo 16v k-series 11.9@118.9 :)
17th May, 2007 at 08:39:04am
Only the turbocharger gives you owt fer nowt ..by using waste exhaust energy .. while a supercharger uses some engine power very, very incorrect. A turbocharger uses a significant amount of energy to drive it - sure - a lot of this energy is from the heat contained inside the exhaust gasses, Of course it uses energy .. but it's using energy that would otherwise be wasted ! So it is correct ,,, very correct. A supercharger uses energy (power) that the engine has to generate, that would not otherwise be wasted! |
17th May, 2007 at 08:57:46am
The turbine needs energy to drive the compressor. That energy is in the form of pressure, temperature and velocity.
44 Posts Member #: 1645 Member Adelaide Australia. |
17th May, 2007 at 11:36:01am
I have a supercharger. Why? Here is Aus, it's much cheaper, it's easy, they look nice when all polished up, a hell of a lot less piping, tons less heat, can be switched off for any reason (I never do though) and give me the torque I need. (I live in a very hilly, country area).
Supercharged 1964 Morris 850 - Now 1330cc with 7psi.
17th May, 2007 at 12:39:49pm
On 16th of May, 2007 at 07:27pm josh_tacon said:
do you realy need both? when you can gget 200bhp woth turbos?? i dont know weather you would benifit anything by having more than 200+bhp in a front wheel drive mini! not sensibly anyway! lol Sensible, maybe not ....... Fun ..... oh yes!!! It's like anything else isn't it, excess is only excess if you view it to be. You drive the car, you are responsible for the throttle angle ..... you get what you want. There are plenty of boost controlers and ecus that can bring the boost in progressively over a load / speed range to help ease things a long and make it nicer / easier to drive. Anybody fitted a working traction contol system to a Mini? I started fitting toothed wheels to the inner CV's and sensor brackets many years ago .... before I took the car of the road to "freshen her up" (translated means sit under a cover untouched, except to rob bits off, for years!!). A friend of mine who is an electronics wizz had made me a basic soft spark cut traction control unit that would probably have worked well in a straight line. MS2 has traction control capability .... can be liked to the boost control as well as fuel / ignition IIRC. Worth a though if your worried about putting it on the road! Every day is a school day ...........
and drivability.
