| Home > Help Needed / General Tech Chat > Megajolt comminication problems | |||||||
17th May, 2007 at 10:34:21am
So far I have everything wired up and I have tested that the MJ unit has a good earth and power supply so it seams to be live. I am using a USB COM adapter but alas it doesn't seem to be communicating with my laptop (the "commit configuration to flash" button is not lit up). Under device manager there is no options for changing buffers and baud rates and I can't even find my USB ports under device manager, just "universal serial bus controllers- USB root hub". There's no options for changing anything under this other than the driver etc. I am using 3.2.1 version of the software and I have tried changing the COM ports in the config thing. What am I doing wrong? Did a search and I've tried all that was suggested so far in the threads.
On 7th Nov, 2008 Nic said:
17th May, 2007 at 11:27:15am
USB serial adaptor....
AlexF |
487 Posts Member #: 1495 Senior Member |
17th May, 2007 at 11:36:38am
Serial Adapter is a COM adapter.
Edited by webba on 17th May, 2007. |
17th May, 2007 at 11:49:18am
Agree with Edmond.
17th May, 2007 at 12:29:46pm
What happens when you click "get ignition configurations", does that work? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th May, 2007 at 02:24:14pm
What if I scabbed an older laptop with a COM port from someone, that would rule out my laptop and the adapter? A girl in my work has an ideal laptop to borrow but I'm shy around girls... I can't remember what it did when I tried to get a config, I know it said at the bottom of the configurator that it "couldn't open port". On 7th Nov, 2008 Nic said:
17th May, 2007 at 03:58:00pm
Get a real serial port and a mouse extension cable NOT a rs232 cable.
AlexF |
17th May, 2007 at 04:34:20pm
So I take it using the following adapter is a bad idea?
17th May, 2007 at 06:00:22pm
I use this one:
17th May, 2007 at 06:44:35pm
jay, that one should be fine.
18th May, 2007 at 12:30:52am
I don't think I have a single computer here still with a real serial port on it except my old file server in the loft. Getting harder to find even on desktop motherboards unless the board is intended for lab / instrumentation use.
18th May, 2007 at 06:34:27am
18th May, 2007 at 10:14:34am
On 18th of May, 2007 at 12:30am RogerM said:
I have used Rob's usb - serial adapter with no problems so some do work, but many don't seem to (including the one on my Athlon board.......) Dead right - some do and some don't. I've had a MJ sent back for repairs this week as the guy can't make it communicate - but it works just fine on mine.... alex AlexF |
18th May, 2007 at 10:21:14am
I will give it another go tonight and if still no joy maybe try another adapter. Still haven't got the VR sensor mounting braket done yet anyway! On 7th Nov, 2008 Nic said:
18th May, 2007 at 10:34:02am
PS, yes I'm running XP but I can't see COM/LPT under device manager, just host controlers and USB root hub. There isn't any options to do anything other than change power settings and drivers either. I'll try and get hold of the local IT dude in my work here. Thanks for your help! On 7th Nov, 2008 Nic said:
18th May, 2007 at 11:04:08am
Just a thought....
AlexF |
18th May, 2007 at 11:42:20am
Good point, I got a CD with the unit with solfware and firmware all on it so I'll just stick with that. Tonight should yield a few answers and hopefully some sparks. On 7th Nov, 2008 Nic said:
43 Posts Member #: 1124 Member Surrey |
18th May, 2007 at 02:07:07pm
On 17th of May, 2007 at 03:58pm AlexF2003 said:
Get a real serial port and a mouse extension cable NOT a rs232 cable. You want all 9 pins of the serial port to connect to all 9 pins of the MJ. Tom, its Edmund
Alex I use a RS232 I got in maplins, works perfectly with my IBM USB port adapter. |
18th May, 2007 at 04:09:23pm
18th May, 2007 at 04:30:06pm
Tom, its Edmund
Damn, close though !
18th May, 2007 at 06:40:35pm
Ah thanks Bat. Mines a little different though, it says PCI to USB Open host controller, PCI to USB Enhanced Host Controller and 3 USB Root Hubs which I assume corresponds to my 3 USB ports. There isn't any options under these to adjust anything at all other than mess with the drivers and power options. Must nip out to the mini with the laptop now... On 7th Nov, 2008 Nic said:
18th May, 2007 at 06:45:28pm
18th May, 2007 at 06:45:46pm
You're looking under Universal Serial Bus in the device manager.
18th May, 2007 at 08:21:03pm
No there is no COM or ports under device manager. Trust me to have a freaky laptop. How do I post a screen shot? On 7th Nov, 2008 Nic said:
18th May, 2007 at 09:23:04pm
On 18th of May, 2007 at 08:21pm Jay#2 said:
No there is no COM or ports under device manager. Trust me to have a freaky laptop. How do I post a screen shot? Press print screen, this will copy the screen to the clipboard. Then just paste this into your editor of choice and save it off. |
