| Home > Help Needed / General Tech Chat > its just not sarting :-( | |||||||
![]() 192 Posts Member #: 837 Advanced Member rugby |
29th Aug, 2007 at 10:08:29pm
ok then here we go
29th Aug, 2007 at 10:11:53pm
Are you sure you have the carb connections all correct as a starter for 10?
29th Aug, 2007 at 10:20:04pm
wow that was quick,
29th Aug, 2007 at 10:21:42pm
The easy start will let you eliminate if its fuel or not. If it fires up on easy start then you need to look at the carb/fuel side.
29th Aug, 2007 at 10:29:13pm
got the plug leads on the right way?
29th Aug, 2007 at 10:36:46pm
yep that was the first thing i checked
29th Aug, 2007 at 11:30:36pm
29th Aug, 2007 at 11:35:42pm
Have flame retardant gloves and a fire extinguisher to hand if you do this, ask Turbo Dave.......
29th Aug, 2007 at 11:40:01pm
29th Aug, 2007 at 11:41:14pm
It flashes at a lower temp, however it also evaporates quickly too! Although when getting th DON running I lost all the hair off my arm due to a spitback!
567 Posts Member #: 102 Post Whore Pennsylvania USA |
29th Aug, 2007 at 11:53:26pm
Have you had the dizzy drive out? If so it could be 180 deg out. |
30th Aug, 2007 at 02:16:02am
On 29th of Aug, 2007 at 11:53pm colas said:
Have you had the dizzy drive out? If so it could be 180 deg out. Are you sure its not 180 out? just because it is at TDC when the rotor points at No 1 isn't enough...Take the plugs out, stickyour finger over the No 1 hole and get it onto the compression stroke, when it is it will blow air.... Then whip off the distributor cap and make sure the rotor is pointing at the No 1 lead.. Edited by Turbo Tel on 30th Aug, 2007. website:- http://www.terryhunt.co.uk
30th Aug, 2007 at 05:03:16am
Could also check for compression stroke by getting rocker cover off and looking for when both valves are shut.
30th Aug, 2007 at 08:11:19am
im sure i checked all that when i was building it,
30th Aug, 2007 at 01:25:57pm
Yes the drive only goes one way, do you have it the correct way? |
30th Aug, 2007 at 01:44:21pm
On 30th of Aug, 2007 at 05:03am Tom Fenton said:
Could also check for compression stroke by getting rocker cover off and looking for when both valves are shut. Yea-- but sticking your finger in a hole is much more satisfying... but Toms way is probably easier.. Edited by Turbo Tel on 30th Aug, 2007. website:- http://www.terryhunt.co.uk
194 Posts Member #: 1296 Advanced Member Milford Haven Pembrokeshire |
30th Aug, 2007 at 03:40:19pm
On 30th of Aug, 2007 at 01:25pm colas said:
Yes the drive only goes one way, do you have it the correct way? I thought there was a few different positions and in the manual there's procedure for drive installation with number 1 at TDC the large side of the slot is at 9 o'clock or something like that. |
30th Aug, 2007 at 03:50:11pm
easy way for a+ dizzy is to put no one at tdc( use the timing mark and make sure you are rotating then engine the right way and the inlet has just closed).
30th Aug, 2007 at 05:51:08pm
cheers guys i think i will check that out before the petrol thing, its hopefully bound to be something stupid like that |
30th Aug, 2007 at 10:36:34pm
right bit of an update,
30th Aug, 2007 at 10:37:32pm
Easy start.
30th Aug, 2007 at 10:57:50pm
will try that next mate cheers
31st Aug, 2007 at 02:17:07pm
On 30th of Aug, 2007 at 03:50pm turbo hogster said:
easy way for a+ dizzy is to put no one at tdc( use the timing mark and make sure you are rotating then engine the right way and the inlet has just closed). fit dizzy drive in so it sits at 1 oclock ( thats the wider section) Like this?:
then fir dizzy so amplifier is plump in the middle of the clamp. Like this?:
bingo she will fire first hit if thats the problem. |
71 Posts Member #: 316 Advanced Member Staffs |
31st Aug, 2007 at 03:19:18pm
Check you have no bends kinks in your fuel pipes, I know it might sound daft but also check you have the pipes the rigth way round on the tank. |
31st Aug, 2007 at 03:51:30pm
Looking at those pictures I would say the wider section is at 10 o-clock.EDIT-looked at haynes and it looks correct-- But no matter as long as you have the #1 lead connected to the cap at connector nearest the vacume cannistor.
Edited by Turbo Tel on 31st Aug, 2007. website:- http://www.terryhunt.co.uk
