| Home > Help Needed / General Tech Chat > advice, ideas and diagnostics | |||||||
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
18th Jun, 2008 at 09:07:24pm
right basically my headgasket went a few months ago... so i took the head off... sent it to benross had the work i wanted done as the head was off... put it all back on... changed oil let it tick over for about 20 mins... then took it for a lap round the block... then i changed oil again... but it is smoking alot from the exhaust
cant beat a good blowout. |
18th Jun, 2008 at 09:14:16pm
18th Jun, 2008 at 09:25:48pm
yer i fort white smoke ment water... benross did alot of work on my head so that is ok and ready to go on... its jsut a standard turbo set up... doesnt seem that im loosing water or oil...
18th Jun, 2008 at 09:30:05pm
18th Jun, 2008 at 09:35:49pm
ok so if that is my problem... waht is the problem lol ???
18th Jun, 2008 at 09:48:33pm
18th Jun, 2008 at 09:57:47pm
May be worth re-torquing the head down with another torque wrench, yours could be out of calibration? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
18th Jun, 2008 at 09:58:14pm
oh soooo either way its bad news lol.. im gona get it set up by bill richards as he is close then if it is still abd then i will have to re think things On 27th Apr, 2010 Rick.SPI said:
19th Jun, 2008 at 10:54:57am
i dont think the head is cracked... well i hope it isnt... i jsut rmebr i didnt flush the oil cooler out so maybe still water in it?
19th Jun, 2008 at 11:18:58am
firstley the heads fine ...i can assure that!! Edited by BENROSS on 19th Jun, 2008.
19th Jun, 2008 at 11:30:06am
I thought that I was the only dummy that used a dodgy torque wrench.
In the 13's at last!.. Just |
19th Jun, 2008 at 10:22:03pm
so maybe the headgasket has gone again which will mean smoke... what im gona do is wip the head off... and start over... new gasket new oil and use 2 wrenchs... i will take my grandads snap on one and the one we used which is teng tools i think.. On 27th Apr, 2010 Rick.SPI said:
19th Jun, 2008 at 11:32:27pm
19th Jun, 2008 at 11:48:32pm
20th Jun, 2008 at 12:07:35am
as Bat says Please do that first!
Edited by BENROSS on 20th Jun, 2008.
20th Jun, 2008 at 09:11:00pm
just had my firend round who is admin on punto sports and runs a very fast punto gt... knows his stuff about turbos...
20th Jun, 2008 at 09:13:04pm
also... the smoke smells very fuel like... and the tapets are not done!
20th Jun, 2008 at 09:13:41pm
black and dry or black and wet?
20th Jun, 2008 at 09:16:09pm
they where dry... so maybe jsut over fueling alot... and the fact it need a dam good set up would this cause smoke? cos it doesnt seem to be loosing any oil or water
20th Jun, 2008 at 09:24:39pm
Why not add your location in your profile, there may be someone nearby to take a look at it for you.
20th Jun, 2008 at 09:29:09pm
I've never seen a car give clouds of smoke due to being too rich,
Edited by Joe C on 20th Jun, 2008. On 28th Aug, 2011 Kean said:
20th Jun, 2008 at 09:51:39pm
if all else fails and you get really stuck with this, does your brake pedal creep at all? if it does whip your master cylinder forward and check inside the servo for any fluid. if there is change your master cylinder. this will cause smoke as well, although the way you are talking im not sure it would cause enough, but alot of smoke to some could be different to others.
20th Jun, 2008 at 09:57:40pm
if i take a video then i will post it... sunday tho
20th Jun, 2008 at 11:25:02pm
20th Jun, 2008 at 11:56:05pm
On 20th Jun, 2008 Tom Fenton said:
Why not add your location in your profile, there may be someone nearby to take a look at it for you. AHEM!!! Unless you are somewhere obscure I'd bet there is someone not far away from you with Mini Turbo knowledge.
