| Home > Help Needed / General Tech Chat > Other rebuild questions... now starting but wont select gears | |||||||
![]() 673 Posts Member #: 1395 Post Whore chepstow |
4th Sep, 2008 at 02:00:56pm
Im starting to get confused about clutches. I've searched and seem to be getting nowhere.
Edited by mayoturbo on 17th Mar, 2009. |
4th Sep, 2008 at 03:01:22pm
4th Sep, 2008 at 03:14:32pm
yes metro is cable operated |
4th Sep, 2008 at 03:15:04pm
Cor what a good link i wonder who wrote that.....:) If you use non genuine parts it should come out at about £300, not really worth skimping on the little items as they could wear later. Once its done its done if that makes sense. You could find a second hand flywheel to reduce the cost a bit. |
4th Sep, 2008 at 03:30:24pm
Unless you have one of the very early Metros with a hydraulic clutch (which would presumably be a Pre-verto anyway) I don't think you can make a Pre-verto work in a cable operated Metro unless you convert to Mini type hydraulics for the whole system from the pedal onwards...
4th Sep, 2008 at 03:37:48pm
Does anyone know what sort of clutch the metro challange cars use? |
4th Sep, 2008 at 07:40:52pm
Metros came with hydraulic clutches on both pre-verto and verto, but there were a lot more hydraulic verto clutch cars made. It changed to cable in late 84. |
4th Sep, 2008 at 07:43:32pm
But, irrespective of when they made the change, presumably the cable operation is only compatible with Verto (with the short arm) ???
Edited by Rod S on 4th Sep, 2008. Schrödinger's cat - so which one am I ??? |
4th Sep, 2008 at 08:26:59pm
I think ill see how the turbo clutch will cope. If it cant take the hike in power I will have to find some other way of doing it |
4th Sep, 2008 at 08:37:23pm
http://www.turbominis.co.uk/forums/index.p...&tid=10207&fr=0
4th Sep, 2008 at 09:04:53pm
On 4th Sep, 2008 evolotion said:
http://www.turbominis.co.uk/forums/index.p...&tid=10207&fr=0 some bedtime reading for you ![]() I found that earlier, went way over my head lol... |
4th Sep, 2008 at 09:07:13pm
I have swapped preverto guts in and used the cable, you do end up with a harder pedal with a shorter throw though, not a problem with a std pressure plate, but with a grey it would probably be very hard going and might eat cables.
4th Sep, 2008 at 09:09:36pm
On 4th Sep, 2008 mayoturbo said:
Does anyone know what sort of clutch the metro challange cars use? Yep, pre verto items, most run paddle plates. Obviously on very light flywheels and backplates. JF. On 21st Jan, 2011 fastcarl said:
4th Sep, 2008 at 09:27:08pm
Does anyone know what sort of clutch the metro challange cars use? Yep, pre verto items, most run paddle plates. Obviously on very light flywheels and backplates. JF. Is that using the pre-84 metro parts for the pre-verto? dont supose anyone has pics |
4th Sep, 2008 at 11:08:29pm
This is the only pic I have. Not sure if its any help.
On 19th Jan, 2010 wil_h said:
5th Sep, 2008 at 12:18:09am
bearings you need and the other bits are
5th Sep, 2008 at 10:40:05am
Or im sure Robert could sort you out with a verto clutch if you ask him nicely. lol
Edited by matty on 5th Sep, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
5th Sep, 2008 at 02:22:45pm
i have a spare set-up if you get stuck. On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
5th Sep, 2008 at 02:51:41pm
Bit of a hi-jack but only a quickie, I've just bulilt my clutch+ flywheel assy up for the first time, in situ is the plate supposed to be clamped up between the backplate and flywheel?
5th Sep, 2008 at 04:25:09pm
5th Sep, 2008 at 05:03:02pm
ta! |
5th Sep, 2008 at 07:23:14pm
On 5th Sep, 2008 rubicon said:
i have a spare set-up if you get stuck. From a mini or metro? thanks |
5th Sep, 2008 at 07:34:37pm
Thanks benross I already have the minispares x-pin diff :)
21st Oct, 2008 at 10:39:03pm
I have a kent 266 cam. Do I need to get new timing gears or will standard be ok?
Edited by mayoturbo on 21st Oct, 2008. |
21st Oct, 2008 at 10:59:03pm
standard timing gears will be fine as long as they are not worn. Always fit a new chain. And, no one but YOU can tell what off set key you need, until you measure what the cam is timed at with a standard key On 26th Oct, 2004 TurboDave16v said:
