| Home > Beginners Tech > First things first... | |||||||
![]() 184 Posts Member #: 346 Advanced Member Portsmouth |
28th Dec, 2008 at 09:50:30pm
Hello all,
1310cc TWINK - T Conversion |
28th Dec, 2008 at 10:04:08pm
Sorry 30-150lb/ft even...
28th Dec, 2008 at 10:13:36pm
Cleaning could be done with paraffin, or brake cleaner, meths, white spirit, anything like that will be OK. As for paper, kitchen rolls from the supermarket are fine, I usually go through at least 3 or 4 on an engine build.
28th Dec, 2008 at 10:34:09pm
Awesome,
28th Dec, 2008 at 11:08:05pm
looks good value as well being teng Crystal Sound Audio said:
28th Dec, 2008 at 11:32:01pm
try not to get too much parafin on your skin, its really not great for you, but i still prefer it to the modern water soluble degreasers as you dont have to rinse said parts in water after... "Turbo's make torque, and torque makes fun"
29th Dec, 2008 at 05:59:27pm
29th Dec, 2008 at 06:03:13pm
rub a bit of engine oil over all the bare surfaces, youll using lots when fitting the pots anyway, and if you still need to gap the rings its nothing a bit of kitchen towel cant sort :) "Turbo's make torque, and torque makes fun"
29th Dec, 2008 at 06:40:13pm
Shit, I was going to go down motor factors tommorrow to get some oil - dont have any in the garage...proper n00b question...but will be OK overnight?
29th Dec, 2008 at 06:59:44pm
it wont be in there very long, so just use the cheapest oil you can get, i think most use 10w40 mineral oil
29th Dec, 2008 at 07:17:19pm
as above. although i do cover all the bearings with that red engine building goo.
29th Dec, 2008 at 10:29:55pm
Excellent.
29th Dec, 2008 at 10:42:11pm
Ah, reading all the right stuff, top man!
29th Dec, 2008 at 11:30:21pm
is bearing nip the same thing you use plastigauge for? AKA oil clearance?
30th Dec, 2008 at 12:04:52am
plastigauge will measure the gap between the journal and the bearing bud, so yeah, the clearance oil should take up "Turbo's make torque, and torque makes fun"
30th Dec, 2008 at 09:33:22am
30th Dec, 2008 at 09:58:45am
I guess the machine shop can clean the block after honing decking etc.. On 13th Jul, 2012 Ben H said:
30th Dec, 2008 at 11:16:07am
ahhh right, so they are similar but not the same? |
1st Jan, 2009 at 11:42:25am
1st Jan, 2009 at 11:46:45am
put a couple of peices of wood either side of the vice and grip them up. although it shouldnt damage them, this will be a better safe than sorry approach!
1st Jan, 2009 at 11:49:27am
Good stuff...
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
1st Jan, 2009 at 12:02:56pm
ARP lube is usually supplied with the bolts/studs. I think the torque levels are different if you're using normal assembly lube rather than the ARP stuff but I'm not 100% sure. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
1st Jan, 2009 at 02:13:08pm
it is a slightly more complex version of molybdenum disulfide greese I normly just use some molly on them and it works just fine. On 17th Feb, 2009 Rob H said:
4th Jan, 2009 at 12:00:11pm
4th Jan, 2009 at 12:29:19pm
