| Home > Help Needed / General Tech Chat > cutting / wet sanding new paint | |||||||
30th Jan, 2009 at 04:16:39pm
Hi, what grit paper should I be using to cut the finished paint (2k) before I polish it?
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
30th Jan, 2009 at 04:23:56pm
2000 maybe? thats what i use? its quite hard work though, but i'm always scared of rubbing through!
"Cars are a lifetime of pain" |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
30th Jan, 2009 at 04:37:18pm
u`ll there till next xmas with 2000 use 1000 Everyone knows that instructions only have to be read if the thing doesn't work....
30th Jan, 2009 at 05:00:13pm
i use 1000, then 1200, then frekla g3 followed with frekla 100?
30th Jan, 2009 at 05:20:19pm
Virtually as above, 1000, followed by Farécla G3 then Farécla G10. (And be careful of the edges, of which there are lots on a Mini).
30th Jan, 2009 at 05:33:39pm
cool, thanks guys.
30th Jan, 2009 at 11:53:20pm
I wouldnt go any lower than 1200 tbh . then finish 2000 and as above g3 then g10
31st Jan, 2009 at 11:36:50am
yes a 1000 does seem to much, I used 1200 once and couldn't get a proper proper shine back, it was probably me to be honest!!!!!
31st Jan, 2009 at 12:59:22pm
quick update. I didnt have any 1000 so started with 1200. Been a bit hit and miss so far, good in places not so good in others..
106 Posts Member #: 4636 Advanced Member Uk milton keynes |
1st Feb, 2009 at 10:25:10am
1200 soap and water, rub soap on paper as you start to sand, use a block on flat surfaces. take your time to get a good finish takes time not five mins.
1st Feb, 2009 at 11:46:09am
I have no idea but make sure you get some pictures when its done :) |
2nd Feb, 2009 at 10:36:16pm
100 comes up fine with a good buffer and cutting compound. cheers |
2nd Feb, 2009 at 11:23:46pm
hope you missed a 0 accidently |
103 Posts Member #: 4744 Advanced Member Harrogate, northyorkshire |
3rd Feb, 2009 at 08:36:13pm
i've alway use 1200 then 1500, and alway do any edges by hand.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=262635 |
3rd Feb, 2009 at 09:48:20pm
oh yea, def dont try 100!! |
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
3rd Feb, 2009 at 11:33:42pm
Pics mark Shit Happen's |
4th Feb, 2009 at 10:19:19am
On 3rd Feb, 2009 Markie_D said:
Pics mark we are waiting lol :)
Good luck mate. im getting there but its very time consuming
results are good so far. :) |
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
4th Feb, 2009 at 11:03:45am
On 1st Feb, 2009 druid said:
1200 soap and water The all important soapy water! I use washing up liquid to be honest, works a treat. When I painted my bootlid I used 1500, then finished with g3, G10 then some good polish and the result was great...
4th Feb, 2009 at 12:21:02pm
sorry but what is g3 and g10?? is that a cutting paper? Team www.sheepspeed.com Racing
4th Feb, 2009 at 12:21:52pm
im finding that G3 is a bit harsh.. if the paints not bad im getting away with just G10 following a bit of a rub down with soapy water and 1500
4th Feb, 2009 at 12:24:40pm
On 4th Feb, 2009 Jimster said:
sorry but what is g3 and g10?? is that a cutting paper? its a cutting compound by farecla, you use it following the wet sanding to get the shine back. http://www.farecla.com/automotive.html Edited by MarkGTT on 4th Feb, 2009. |
4th Feb, 2009 at 12:40:03pm
results are good so far. :) I know mate, i'm messing. Look forword to seeing it :) Shit Happen's |
![]() 367 Posts Member #: 1643 Senior Member West London |
4th Feb, 2009 at 03:33:27pm
I wouldn't go no less than 1200, specially on new paint. Lightweight racer coming soon. |
4th Feb, 2009 at 04:26:16pm
sorry but what is g3 and g10?? is that a cutting paper? its a cutting compound by farecla, you use it following the wet sanding to get the shine back. http://www.farecla.com/automotive.html Cheers for clearing that up. so the higher the g number the finer the paste? Can you get different grades of polishing sponge thingys? Team www.sheepspeed.com Racing
4th Feb, 2009 at 05:12:08pm
Cheers for clearing that up. so the higher the g number the finer the paste? Can you get different grades of polishing sponge thingys? No probs, yeah that’s right, and you do get different grades of sponge, for example specific ones for 2k paint, finishing etc |
