| Home > General Chat > Guess whats Fucked | |||||||
11th Mar, 2009 at 01:59:40pm
Right went out for a spin in the Mk1 today to the shops, on the way back I decided to give the pikey engine some abuse got it up to 7800rpm in 3rd and there was an unmerciful bang. There was also a huge jolt and now, every time I try to select a gear there is a grating noise and a huge amount of jolting from the engine. I can get 1st and 2nd 3rd is a non runner and I didn't try 4th. I taught the flywheel might have come loose but have looked in trough the inspection plate and all is fine there.
On 17th Feb, 2009 Rob H said:
11th Mar, 2009 at 04:12:42pm
my gues is input gear on either the input of on the layshaft always looking for them bigger bunches of bannanas |
11th Mar, 2009 at 04:35:41pm
broken layshaft... Yes i moved to the darkside |
11th Mar, 2009 at 05:51:53pm
7800 rpm, wtf have you done to that engine? On 7th Oct, 2010 5haneJ said:
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
11th Mar, 2009 at 05:56:59pm
Diff pin ?
11th Mar, 2009 at 06:29:56pm
my guess its the 3rd gear head set and 3rd gear teeth shredded
11th Mar, 2009 at 07:11:00pm
same as steve. i think something on third gear has shit itself. |
11th Mar, 2009 at 08:01:14pm
Edited by robert on 11th Mar, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Mar, 2009 at 08:04:20pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=168594 Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Mar, 2009 at 08:39:09pm
Yeah definitely sounds like the 'box is broken! Lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Mar, 2009 at 08:59:10pm
Right had another little look at it this evening and it still moves under its own steam with a little coaxing, every time I go from neutral to a gear there is a lot of grating. As it is about to select the gear an gear that is, there is a lot of jolting from the engine I don’t think I have done as good a job as Robert but It sounds pretty fudged. On 17th Feb, 2009 Rob H said:
11th Mar, 2009 at 09:52:42pm
11th Mar, 2009 at 10:51:12pm
Blown head light bulb? |
11th Mar, 2009 at 11:03:13pm
mainshaft bearing, On 28th Aug, 2011 Kean said:
11th Mar, 2009 at 11:10:09pm
Britain is fucked. 9.85 @ 145mph
11th Mar, 2009 at 11:24:16pm
I'll be over Saturday morning to do take the waterpump off the turbo motor. We can pull the gearbox off the turbo too and you can have it On 12th Nov, 2009 Paul S said:
Gary's description is best |
12th Mar, 2009 at 08:53:32am
Cool thanks doood
1050 Posts Member #: 764 Post Whore Staffordshire |
12th Mar, 2009 at 12:28:46pm
i will go with a busted mainshaft bearing |
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
12th Mar, 2009 at 04:06:30pm
i`ll go with drop gears then www.miniman.com.au
12th Mar, 2009 at 05:03:34pm
12th Mar, 2009 at 05:29:42pm
No that is fully functional but I will tell her it needs testing just incase you are right On 17th Feb, 2009 Rob H said:
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
12th Mar, 2009 at 09:26:14pm
Don't know about your gearbox but I would guess one or two of your next weekends are fucked ... Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
12th Mar, 2009 at 09:52:57pm
harsh,
12th Mar, 2009 at 10:21:09pm
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
13th Mar, 2009 at 12:40:49am
On 12th Mar, 2009 Advantage said:
Don't know about your gearbox but I would guess one or two of your next weekends are fucked ... Harsh indeed. Funny coz its true!! Hard luck though, this happened to me shortly after buying my present daily runabout from Aaron down in carrig, http://www.miniresource.com/gallery14.php i found it to be the shaft bearing alright. Sorry for you trouble, regards Colin |
