| Home > General Chat > GT17 Fitment Ins and Outs | |||||||
11th Mar, 2009 at 02:46:41pm
Ok chaps, what Screamer Pipes will fit the GT17s? Also will the gt fit my Metro Manifold With Modification?
11th Mar, 2009 at 02:49:16pm
Try this. :) http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10263
11th Mar, 2009 at 03:11:14pm
Nice one, cheers phil. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Mar, 2009 at 03:20:17pm
I can feel my wallet getting thinner by the second! If something is worth doing, it's worth doing half of. |
11th Mar, 2009 at 03:22:21pm
On 11th Mar, 2009 minimadmotorman said:
I can feel my wallet getting thinner by the second! On 11th Feb, 2015 robert said:
11th Mar, 2009 at 03:27:03pm
Well, doesnt look like screamers are available for the GT :( Probably a good thing really lol.
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
11th Mar, 2009 at 03:54:11pm
No screamer on the gt17 as its all one outlet, think you want a gt20 or something like that?
"Cars are a lifetime of pain" |
11th Mar, 2009 at 04:01:17pm
Ive managed to get a gt17 so im gunna stick with it.
11th Mar, 2009 at 04:13:05pm
I most certainly do, best thing i ever did was take the T3 of! So much less lag, is awesome!
11th Mar, 2009 at 05:30:07pm
Whats it feel like compared to a t3 is it instant power? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Mar, 2009 at 09:54:37pm
almost, it comes in a lot quicker and almost feels sort of modern day turbo car, (like a 20vt VAG engine) but obviously without the clutch and gearbox wine. I had mine rebuilt first properly so i wouldn't be dicking around with it! PM me if you want to know how i did mine.
11th Mar, 2009 at 10:11:53pm
12th Mar, 2009 at 07:38:06am
Stef, what actuator are you using? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
13th Mar, 2009 at 11:27:17am
A grpA style one, think it maybe a forge on. But i know its set at 12 psi min. had the bracket relocated and welded onto the turbine housing
13th Mar, 2009 at 11:01:38pm
13th Mar, 2009 at 11:22:18pm
Whats the purpose of this? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Mar, 2009 at 02:49:22pm
when you slip the turbo on, you will see it will not clear the block and is in fact in the way, so you have to relocate it! you can do it with a steel braket etc....but if you have access to an ali welder why not. "Cars are a lifetime of pain" |
16th Mar, 2009 at 12:24:01am
16th Mar, 2009 at 09:20:35am
mmmmmm i'm getting one of these badboys once my t3'd engine is up and going!! |
16th Mar, 2009 at 12:23:17pm
Does anyone know the threads of the oil and water fittings on these? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
16th Mar, 2009 at 10:42:26pm
hmm i seem to remember the water ones being m14? think the oils are 11mm...but check first. ring CR turbo's there tell you what they are and sell you the various parts you will need? Or have a look on sleeze bay! "Cars are a lifetime of pain" |
17th Mar, 2009 at 07:49:51am
I think youre right about the 11mm, i tried a 7/16 unf banjo and it nearly fits, so 11mm would be the metric equavalant.
On 16th Mar, 2009 ministef1 said:
hmm i seem to remember the water ones being m14? think the oils are 11mm...but check first. ring CR turbo's there tell you what they are and sell you the various parts you will need? Or have a look on sleeze bay! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
17th Mar, 2009 at 10:42:58am
What PSI is the standard actuator of the GT17 set at? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
17th Mar, 2009 at 12:03:49pm
i should think 4? I adapted what i had on the t3, and went from there.
17th Mar, 2009 at 06:19:49pm
mike ,its 5.5 psi as stock on the saab. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
