Home > FAQ / Knowledge > will fiesta caliper fit on 8.4" solid disc?
jom
Member #: 6003
some of people fit on 7.5" disc, i dont know if i can fit on 8.4" disc.
normally it is used on an 8.4" disc turned down to 7.9" diameter.
jom
Member #: 6003
can i put a metal between caliper and the hub . make it to suit the 8.4" disc. or the caliper will touch the wheel? i use 13"wheel
The general idea is that the Fiesta callipers are used as a chep mod to fit 10" wheels.
If you have 13s then just use the standard callipers. If you want and upgrade then fit some 4-pots. although it's only really an upgrade ifyou fit the ally ones. as the Metro ones are really heavy and offer no real benefit to braking.
Fiesta calipers are very rare now. Presumably the pads will soon be unavailable.
Why bother unless you want a cheap way of fitting 10s.
jom
Member #: 6003
okk, i think i should keep the standard calipers and fit a groove disc and better pads on it
A much better idea.
no point going to an 8.4 on F calipers they will just over hang the pad more.
You can get 7.9 pre cut for good prices form places like MRA.
I wander if they've patented 7.9" brake discs?
Edited by Rob H on 10th Jan, 2010.
snigger....
On 23rd Dec, 2009 Rob H said:
I wander if they've patented 7.0" brake discs?
no , just the fiesta pads .
also patented a special kind of piston oil jet...
http://www.theminiforum.co.uk/forums/index...pic=135787&st=0
Andrew 998 mini
Member #: 5639
Weert Holland
fiesta caliper will not fit over the 8.4 discs, and the caliper will also not fit the stadard mini hub you need metro hubs.
I can't explain the full details yet as i am still fiddling with this setup, but the mini is driven practicly every day!!
ther is a guide on youtube ( fiesta caliper conversion ) if you would like to lokk at that.
as for the pads, the MK1 and MK2 fiestas are still seen on track days and these days you can still get Ferodo pads and even EBC green/yellow and red stuff pads
In holland where i am i can still get girling or lucas pads
Andrew
Cheers, Andrew
Little car Little power........... For now That is!!!!!
1983 mini down paid, must collect soon and get welding!
your wrong about the hubs..
Mini hubs & metro drive flanges :)
Ding! Rob H is correct. :)
Andrew 998 mini
Member #: 5639
Weert Holland
Sorry, ( as i wrote i am still working on this) And thanks, that meens that I only need to pull the drive flanges of a metro in a local scrappy
Ive got calipar's And pads (ferodo)
8.4 solid discs turnd down to 7.9" (brembo)
Just need some time and a couple of brake hoses to fit.
Cheers, Andrew
I know, I've been running them for 3 years :)
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10910
about 6 months before me, I like them, but I'm thinking of swapping to a yellow tag MC. What do you run?
Edited by gr4h4m on 10th Jan, 2010.
Andrew 998 mini
Member #: 5639
Weert Holland
Sorry for asking silly questions:$ but, on what are you running the setup? turbo-ed? power? how do they handel spiritid driving , hard brakeing etc. with pads are you useing or do you prefer?
I woul like to know then i know what to expect!
Cheers, Andrew
I'm still running the original Rover MC with built in servo, seems to work OK so why change it.
Embarrassingly the 1293 turbo lump is still sat under the work bench & the mirage kit is in Birmingham I think so the BOC is running a Stage 1 MG Metty lump for now. I found the brakes more than up to any thing I can give them on the roads, managed to get them to lock up in the wet on the way to MITP a couple of years back but never managed to lock the wheels in the dry.
7.9 disc ,mini flanges .
Have you made up some spaces & done some machining on the lathe by chance?
PS. The split tapper collar is the wrong way round.
there may have been a little bit of facing off . *wink* no spacers needed.
