Home > Help Needed / General Tech Chat > fuel starvation?
MarkGTT
Member #: 1194
Shropshire.
Hi, last year i was getting a lean spot in 4th when accelerating hard and running through the gears, for example on the ¼ mile.
It was fine on the rollers and on the road.. im guessing that this was fuel starvation due to the increase in demand.
Last year I was using a heavy weight dashpot oil (motor bike gear box oil) – could this be contributing?
Pump not up to the job? (a new Bosch metro turbo item) or do I need a swirl pot??
Any help / ideas appreciated.
Cheers, Mark
doesnt a heavier spring/oil make the car richer, by restricting the air flow?
Star Mag
Member #: 375
Leicestershire
I can't see the dashpot oil being a problem maybe some 20/50? What sort of condition is the fpr in? I had this problem with mine, fine on the road but the 1/4 was always running lean on a long pull. Maybe check fuel Filters and pressure up the rev range?
sounds like the fuel float bowl is being emptied faster than it can be filled, you can get higher flowing valves,( i cant remember their proper name) its like a sprung loaded pin inside a tube that sits in the bottom of the carb.. yeah that thing *happy*
Edited by Brett on 11th Feb, 2010.
MarkGTT
Member #: 1194
Shropshire.
fpr is also new, fuel filters would be a simple change, i just have some smallish plastic jobbies atm.. could get someting a bit bigger.
MarkGTT
Member #: 1194
Shropshire.
yeah i think avonbar used to do a bigger jet.. will look into it cheers *smiley*
i got the avonbar jet ,it leaked , sent it back and got another one ...it leaked ..sent it back and got an su rebuild kit ,in the box ,and it had as big a jet ,and it didnt leak .
MarkGTT
Member #: 1194
Shropshire.
lol - ok, will try and just find a high flow jet. Any idea what size to go for? Im sure i read something about 2.8mm??
I agree that it sounds like the float bowl is being emptied. Check the pump flow rate in situ.
could be the pump or a blocked filter or a crushed pipe.
n.g.l.
Member #: 181
Chard, Somerset
Mark, what pump pre filter do you have?
I've put one of these on the van and have one waiting to go on my mini:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=400102084426
Seems good for the money. I would expect small plastic ones to be a bit of a restriction.
MarkGTT
Member #: 1194
Shropshire.
thanks for the link - that looks a more substantial, definitely worth a try
MarkGTT
Member #: 1194
Shropshire.
also just a thought the plumbing should go
tank (obviously) - pump - filter - fpr
right?
Edited by MarkGTT on 11th Feb, 2010.
If you are using a metro turbo type pump I would personally go Tank-Filter-Pump-FPR.
n.g.l.
Member #: 181
Chard, Somerset
The roller vane type fuel pump needs to have a good prefilter, without it is a sure fire way to damage it. The damage might not be noticable on say a standard Metro Turbo, where even at full throttle alot of the fuel will be returned to the tank, from the FPR. We are not running standard engines and at full throttle the engine is consuming a large amount of fuel. If the pump's internals are worn from contamination then the flow rate will drop off. I think you maybe looking at a pump replacement to solve your problem, but then I'm usually wrong *hehe!*
MarkGTT
Member #: 1194
Shropshire.
umm.. something else to think about then - Thanks.
I haven't done many miles on the new pump so i hope its not damaged.. will get a new filter and re-plumb it in the right place - see how i get on.
Star Mag
Member #: 375
Leicestershire
I tried to drill a couple of jets out but they always seemed to leak. I couldn't get them to seal no matter why I tried. I'm still after a bigger jet.
simple test is to turn up the fuel pressure till it just affects the tickover ,then try it .if its better ,then its a float needle problem not a pump problem.
have you got the T peice trick installed ?
MarkGTT
Member #: 1194
Shropshire.
nope..
this is where you 't' the plenum to the top of the fpr then to the pipe in front of the fuel inlet on the carb (normally blocked off) ??
Brocky
Member #: 224
Katy TEXAS
Hey Mark,
Tee piece trick is covered in the lower half of this post - see link (in 3). :)
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
its also worth blocking off the part throttle lean off pipe if you haven't already
I also seem to be suffering a similar problem in top gear after being flat out for a while.
First thing I'm gonna do is fit a higher flow filter, then look at the pump, then needle valve etc.
My pump has a very slight leak on the body so I need to replace it anyway...
Also float extension piece is useless you extend the jet intake down also.
Let us know how you get on.
You can bore the valve out to 2.9 mm and then relap the seat, there has been another post on this fairly recently.
This is another one I found
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=130362
Also (obviously) make sure you have a good feed from the tank?
I took out the orignal pick up pipe and fitted a 10mm pipe so it matched the inlet size on the pump and ran nice fat 10mm fuel line between tank to filter and pump. Make sure filter has 10mm tails.
Brocky
Edited by Brocky on 12th Feb, 2010.
MarkGTT
Member #: 1194
Shropshire.
Hi Brocky, yeah part throttle lean off pipe is blocked off.. unfortantley it looks like there is a stud in the carb were i need to 't' into (anti run on valve) .. so it going to be a pain to remove.
will check the carb to plenum gasket, change the filter first.. and cross my fingers!
If you're wantintg to try the bigger needle valve, you can drill it out yourself and just lap the needle into the seat with some fine paste. I did this about 4 years ago & have had no issues.
Brocky
Member #: 224
Katy TEXAS
Mark,
My current carb looks like it never had the run on port even drilled... but my spare carb has both.
Just occured to me, would the tank breather size have any effect if it was too small ?
As I'm sure at full tilt the fuel is leaving the tank pretty quickly?
Phil,
Did you figure out what was causing your problem in the old post above ?
Brocky
watsonrodriguez
Member #: 8270
hello.
Fuel starvation are problems that can affect internal combustion engines fuel led by either diesel, kerosene, petroleum or any other combustible liquid or gas.If no fuel is available for an engine to burn, it cannot function. Fuel starvation is slightly different from fuel exhaustion, in that fuel is in the tank but there is a supply problem which either fully or partially prevents the fuel from reaching the engine.
private villas bali
