| Home > A-Series EFI / Injection > VE tables vs. engine characteristics | |||||||
20th Aug, 2010 at 04:07:46pm
last year, test engine ran fine on 680cc injectors and I could easily get AFRs above 13 at idle and nice smooth running.
20th Aug, 2010 at 04:22:57pm
I think that you have answered your own question.
Edited by Paul S on 20th Aug, 2010. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Aug, 2010 at 04:35:49pm
OK Paul,
20th Aug, 2010 at 05:23:19pm
I'm running around 9:1 on the 998Ti.
20th Aug, 2010 at 08:39:32pm
when my engine was a low compression slug i needded idle afr's around 13:1 to get a decent idle. i could, however, get the afr's higher!
20th Aug, 2010 at 10:22:04pm
should add, i use the injector opening time as a fudge to improve ide afr / transients without really affecting WOT conditions, has a very pronounced effect. perhaps you have an issue with some correction on the injector opening time? like battery voltage? turbo 16v k-series 11.9@118.9 :)
20th Aug, 2010 at 11:26:39pm
Denis,
21st Aug, 2010 at 07:37:13pm
Well this is weird......
22nd Aug, 2010 at 01:41:25am
Do you only get the glitches on the gauges of go you also have the engine stumbling? If it's only the gauges, it could be comm issue only depending if you're using MT, MTx or TS. The longer burn might also be a comm issue.
22nd Aug, 2010 at 07:36:02am
Thanks Jean,
22nd Aug, 2010 at 08:54:31am
perhaps stick the sensor in the pipe from the ic rod ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Aug, 2010 at 09:00:03am
22nd Aug, 2010 at 10:41:55am
On 22nd Aug, 2010 Rod S said:
I't difficult at the moment to say whether the glitches on the gauges are cause or effect - because I'm far too rich at the moment it's not idling particularly smoothly so although a jump on a gauge seems to coincide with a "jump" in the engine note it's not yet clear if the gauge is reading simply what is happening or something in the comms is the cause. ie, pulse width gauges suddenly dip and engine falters - was it a rich misfire causing the engine to instantaneously lose speed so the pulse width drops and the gauge is reporting it correctly, or is some glitch causing the pulsewidth to drop suddenly so the engine falters as a result. Pulse widths should not dip as a result of a misfire. PW = REQ_FUEL * VE * MAP * E + accel + Injector_open_time and E = gamma_Enrich = (Warmup/100) * (O2_Closed Loop/100) * (AirCorr/100) * (BaroCorr/100) Nothing to do with rpm at all. If anything I would expect an increase in PW due to the increase in MAP. So it has to be something to do with MAP, MAT or AE. My money is on AE. I know that you think that you have set AE not to come in at idle. So did I at one point, but still found that although the engine was running below the lower AE threshold, I needed to increase all the settings by a factor of 10 to get the engine to idle at all. Have you calibrated your TPS? Have you got a steady TPS signal? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Aug, 2010 at 02:37:46pm
Paul, as an aside, RPM is part of the equation (which is deriven from the universal gas equation pv+mRT), it's just "hidden" in the MegaSquirt version as part of "VE" (VE values allways rise with RPM, see your own table above).
22nd Aug, 2010 at 02:47:01pm
Try and log or observe Gammae. If that is steady when the stumbles ocurr, then it will be AE. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Aug, 2010 at 02:54:09pm
Will do - it will be tommorow now, I'll leave the battery on a trickle charge overnight.
22nd Aug, 2010 at 02:58:53pm
Oh right,
22nd Aug, 2010 at 03:59:45pm
Paul, as an aside, RPM is part of the equation (which is deriven from the universal gas equation pv+mRT), it's just "hidden" in the MegaSquirt version as part of "VE" (VE values allways rise with RPM, see your own table above). Not in the idle area :) I've found that idle will never be smooth if the pulse width is wandering around a hilly VE table. Hence my table is flat below 1200 rpm and 50kPa. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Aug, 2010 at 04:30:16pm
Paul, as an aside, RPM is part of the equation (which is deriven from the universal gas equation pv+mRT), it's just "hidden" in the MegaSquirt version as part of "VE" (VE values allways rise with RPM, see your own table above). Not in the idle area :) I've found that idle will never be smooth if the pulse width is wandering around a hilly VE table. Hence my table is flat below 1200 rpm and 50kPa. Excellent point - mine being the "standard table, as yet un-modified in that area, more than doubles diagonally over the bottom left 5X5 cells.
Hence why a drop in pulse width with a drop in RPM didn't surprise me at all. As you say, yours is totally flat over the same block. It's really why I asked the question in the first place, but I've not really be able to look at that aspect in detail whilst I can't get the engine running steadily or get it to restart when hot...... However, my VE table, although wrong, is clearly not the issue as the JimStim shows something is adding fuel below 2kRPM, not taking it away as my VE table would suggest. Schrödinger's cat - so which one am I ??? |
22nd Aug, 2010 at 05:31:05pm
And, Robert, moving the sensor would be a bodge and it isn't that difficult to enlarge the hole and sleeve it, your far more likely to get information that directly reflects the air temp from a location removed from a plenum that suffers almost direct heating from the exhaust . whether you insulate it with nylon or blocks from the space shuttle , youll still get radiant heat from the inside of the plenum ,that wont necessarily be the same as the inlet air temp , depending on air speed and the entering air temp from the ic ,there will be a variable on how much heat the air pics up in the plenum . .heat soak in traffic into the plenum could and probably will be significant ,and a sudden blast of highway driving cooling the air and making it denser ,would not be reflected by a sensor soaked in the balmy plenum environment .. better byy far to have it in the inlet pipe to reflect a real world condition .or at least be more immune from plenum heat and closer to air temp fluctuation . but hey ,you can always move it again later .i may be totally wrong . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Aug, 2010 at 05:46:57pm
On 22nd Aug, 2010 robert said:
your far more likely to get information that directly reflects the air temp from a location removed from a plenum that suffers almost direct heating from the exhaust . whether you insulate it with nylon or blocks from the space shuttle , youll still get radiant heat from the inside of the plenum ,that wont necessarily be the same as the inlet air temp , depending on air speed and the entering air temp from the ic ,there will be a variable on how much heat the air pics up in the plenum . .heat soak in traffic into the plenum could and probably will be significant ,and a sudden blast of highway driving cooling the air and making it denser ,would not be reflected by a sensor soaked in the balmy plenum environment .. better byy far to have it in the inlet pipe to reflect a real world condition .or at least be more immune from plenum heat and closer to air temp fluctuation . but hey ,you can always move it again later .i may be totally wrong . Robert, interesting thoughts - don't get me wrong, I don't reject your arguements..... The thing with the fuelling equation as I see it is it needs to know the air temperature of the air actually entering the cylinders to do the pv=mRT calculation. At Idle speeds (when I can actually get it running consistently at idle) that temperature will be well above ambient simple because of my poor (with the benefit of hindsight) design of the inlet. Once the air flow increases the bulk temperature will drop as there is far too much mass for my poorly designed inlet to keep hot. So I'm still thinking I need to read the actual temperaure of the air inside the plenum when its running, even if that temperature is being raised by radiant heat, and stop the sensor then giving a false value when restarting after the sensor has been hit by heat soak and the air flow is too low to correct it. That's my logic so far but I still need to understand why I go rich below 2k RPM leading to the stall as the MAT issue then becomes irrelevant :) Schrödinger's cat - so which one am I ??? |
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
22nd Aug, 2010 at 06:04:24pm
I'm sure you have this set correctly, but do you have multiply map set to "multiply"?
’77 Clubman build thread
22nd Aug, 2010 at 06:16:00pm
Just as a test to make sure that it is not a calculation issue.......
22nd Aug, 2010 at 06:25:04pm
Ahhhhhrrrrggghhhh
22nd Aug, 2010 at 06:39:00pm
UNBELIEVABLE....
