| Home > General Chat > WAY OT- Gas Plumbing Question | |||||||
7th Mar, 2006 at 11:18:23am
Any plumbers here? I am in the middle of building a workshop which is not attached to my house. I want to run gas into the workshop so I can install a boiler. What is the correct way to run Gas underground, through a mixture of soil and concrete? Team www.sheepspeed.com Racing
![]() 41 Posts Member #: 927 Member port talbot, south wales |
7th Mar, 2006 at 11:20:59am
my dad owns a kitchen & bathroom shop in maesteg ring him and he'l help you if he can? 01656 733519 |
7th Mar, 2006 at 11:24:12am
Edited by Bat on 7th Mar, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
7th Mar, 2006 at 11:27:11am
I was thinking about getting an oil fired boiler, that way you can just have a small tank outside and top it up with red diesel etc to burn as heating fuel?
7th Mar, 2006 at 11:30:20am
7th Mar, 2006 at 11:35:34am
what size can you get the yellow pipe in? I've only seen it in a silly large size, I want around 22mm Id as I don't want to much pressure drop over the long distance. Team www.sheepspeed.com Racing
![]() 2102 Posts Member #: 432 Post Whore Swindon |
7th Mar, 2006 at 11:48:02am
i thought all gas work had to be completed by a corgie approved installer now........... |
7th Mar, 2006 at 11:49:08am
it does |
7th Mar, 2006 at 11:50:28am
On 07/03/2006 11:48:02 Vinyl-Graffix said:
i thought all gas work had to be completed by a corgie approved installer now........... I know. It's not me doing the work you'll understand, it's a 'friend' Team www.sheepspeed.com Racing
7th Mar, 2006 at 12:01:02pm
an oil boilers the way! i have wayed it ALL up with the price of gas going up. Edited by BENROSS on 7th Mar, 2006.
7th Mar, 2006 at 12:27:21pm
still 47p a littre, the same friend of mine use to use kerosine and oil mix, worked a treat on his cough! Team www.sheepspeed.com Racing
7th Mar, 2006 at 02:55:59pm
7th Mar, 2006 at 03:54:30pm
cheers Gav, I'll go get some of this stuff.
7th Mar, 2006 at 04:32:44pm
7th Mar, 2006 at 05:48:50pm
I'm posh!! I have gas leak detection spray. works pretty well too. not that I've used it, my 'friend' told me about it Team www.sheepspeed.com Racing
7th Mar, 2006 at 06:31:07pm
Jim, I would lay a bed of red sand down after the pipe, that way anyone in the future will notice it when digging.
7th Mar, 2006 at 08:54:16pm
will do, good tip Team www.sheepspeed.com Racing
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
7th Mar, 2006 at 09:59:02pm
on the oil burner thing. red diesel was 36p a litre iirc when i had to buy it last time. that was at a small garage out on the fun roads, but theres a texaco that does it and its int he high 40s near me. sounds cheeper than veg oil if anyone else decided to go that route :)
7th Mar, 2006 at 10:22:18pm
1300 Posts Member #: 829 Post Whore essex |
7th Mar, 2006 at 10:36:35pm
when you run the pipe you can buy tape with GAS on it
1293 Turbo mini
8th Mar, 2006 at 08:28:12am
good tip Jimmy, thanks for that Team www.sheepspeed.com Racing
10th Mar, 2006 at 01:57:25pm
jim, can i have your car when you die? |
13th Mar, 2006 at 11:20:05am
yea no problem nic Team www.sheepspeed.com Racing
13th Mar, 2006 at 07:00:40pm
cheers, though dont make it too soon |
13th Mar, 2006 at 07:14:12pm
nic ,i want the 5 grand in used notes ,dont forget,
You can't beat nice warm rads in the garage! Mmmm toastie!
