Home > General Chat > New twist on dizzy's
Anyone seen these:
http://www.123ignition.nl/id/20.html
apparently you can flick between loads of preset curves to find one that will suit any engine...wonder if there is a turbo compatible setting?
I think its a good idea, but still gonna go with the MS.
Jo
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Its nearly the price as the MS and is still only 2d!!
The whole advantage of MS is that you compair engine speed AND load to give you the spark advance.
Alex
AlexF
I lifted this from their pdf FAQ file, thought it might be of use to someone trying to figure out a suitable ignition curve for an aftermarket ECU:
(Apparently setting 7 is suitable for metro turbo applications)
Technical data
Operating voltage 4,0 to 15,0 Volts, negative earth only
RPM range 600 to 7000 rpm
Temperature -30 to 85 degrees Celsius
Coil stock coil or "High Energy"-coil, primary resistance not below 1 ohm.
engines all MINI engines ; advance-curves selectable by a switch through the
bottom of the housing
Curve Advance Advance maximum
500-1000 @ 2000 @ 5000
0 10,0 14,5 28
1 10,0 16,7 28
2 10,0 18,4 28
3 10,0 20,2 28
4 10,0 16,3 30
5 10,0 17,6 30
6 10,0 19,4 30
7 10,0 21,1 30
8 10,0 16,2 32
9 10,0 18,1 32
A 10,0 20,3 32
B 10,0 22,9 32
C 10,0 17,0 34
D 10,0 20,4 34
E 10,0 22,1 34
F 10,0 23,9 34
* degrees advance and engine speed both relate to the crankshaft
curve Application and/or Engine Number
number
C 848 Mini UK Vehicles Regular Fuel
F 850 Mini
3 997 Mini Cooper HC
C Mini Cooper S Mk III, 1275 cc
F 997 Mini Cooper LC
C Minor, Van and Pickup, 1098 mini Low Compression
4 Mini early including Wolseley Hornet and Riley Elf
F 850 mini Late Model High Compression
F* 998 Mini Cooper High Compression
F* 998 Mini Cooper LC and special order for low
grade fuel
B Works special for Rally Mini's
E 848 Mini UK Vehicles Premium Fuel
0 Mini 1000 Saloon, clubman and Estate, 998 cc,
F* 998 Mini Cooper HC, 1971-75 Morris Marina 1.8 TC
E Mini Cooper S Mk III, 1275 cc
A 998 mini Early Model High Compression
B 998 mini Late Model High Compression
A 850 and 998 Mini Automatic including Riley Elf and
Wolseley Hornet, 1100 automatic
B Mini 1000 and Mini Clubman, Saloon and variants,
998 cc,
2 1275 non S Mini, Austin 1300 HC and automatic,
Riley Kestrel 1000, Wolseley 1300 and Vanden
Plas Princess 1300, MG 1300 Automatic
A 850 and 998 Mini automatic, Vandel Plas Princess
1300 and Wolseley 1300 twin carb
998 cc, 1972-74: Mini Clubman 1100, 1098 cc,
Allegro 1100
F Later Minis and Moke
C Mini Moke, van and pickup, later models
A 850 and 998 Mini Automatic including Wolseley
5 998 Mini 72 to 74 including Wolseley Hornet and
Riley Elf
D 998 Mini Cooper, late
2 1275 non S Mini, Austin 1300 HC and automatic late
0 998 Mini (Canada) 1975-80, 1974 onward Leyland
(SA) 1.3 van, 1974-77 Morris Marina 1.3, 1975-78
Morris 1.3 HC
4 1970-73 Austin 850 LC, 998 Mini automatic, 850
van and pickup, 1976-78 Morris Marina 1.8 GT and
HL
B Mini 850 Saloon and variants, 848 cc
5 Austin 1000 Mini automatic and Clubman, 1975
Authi Mini 1000
A 1969 Austin 850 Mini automatic, 1976-80 Austin
850 Mini, 1970-80 Austin 1000 Mini automatic,
1976-80 Austin 850 van and pickup, 1970-77
Austin 1100 Automatic,
8 Mini 1000 and Mini Clubman, Saloon and variants,
998 cc, manual and auto, Allegro 1.1
0 1970-80 1275 non S Mini, 1973-79 Austin Allegro
1300 HC,1969-74 Austin 1300 HC Automatic, 1970-
74 Austin 1300 France, 1969-73 Austin 1300
Princess including automatic
C 998 Mini (Canada)
F* Mini 850 Saloon and variants, 848 cc
5 850 Mini, van and pickup
B Minis with engine number 12HC18AA, 12HC19(AA),
12HD20(AA) 12HE41, 12HE42, 1984 onward Austin
Metro 1.3 van, 1981 onward Morris 440, 575 Van
and Pickup 1.3
4 Metro 998, Minis with engine number 99Hxx, 1988-
onwards.
D Minis with engine number 12HC09AA, 12HC10AA,
12HD14(AA) 12HD15(AA), 1983-84 Austin Metro
1.3 HLE
2 Minis with engine number 12A2BG01, 12A2BG03,
12A2BG05.
4 Minis with engine number 12HD09, 12HD10,
12HD11, 12HD12, 12HD13, 12HD21, 12HD22, 1984-
86 Austin 1.3 L and HLE
4 Minis with engine number 12HD17, 12HD24, 1986
onward 1.3 Vanden Plas, 1984 onward MG Metro
7 Minis with engine number 12HD26(AA) 1984
onward MG Metro turbo
A Minis with engine number 12HC17AA, 12HD18
4 Minis with engine number 12HD25
6 Minis with engine number 12HE48, 12HE25
* These engines require more maximum advance than the 123/Mini can provide, but curve F should allow the engine to operate well.
bollocks, i spent ages getting the spacing correct!!!
ill put it in a spreadsheet.
Different curves:
http://www.turbominis.co.uk/index.php?p=20&id=1992
Curve Application:
http://www.turbominis.co.uk/index.php?p=20&id=1993
Edited by joeybaby83 on 22nd Mar, 2006.
Whilst it may well be only 2D, and the same cost as Megawotsit, for 95% of peeps, it is a better option.
Inside of ten minutes, you can transform your ignition system from a points dizzy to what is damn near the ultimate, with nothing more than a 7/16 spanner and a few terminal connections. No Loom to make, no mounting of map sensors, no hassle full stop.
MJ/s vs 123 is like comparing apples with pears at the end of the day; incidentally of which, one of which is nice to eat and usefull in cooking, the other which is soft as shite and unpleasant or hard as knockers and gritty as hell.
Edited by turbodave16v on 22nd Mar, 2006.
Dangerous
Member #: 417
On 22/03/2006 16:16:31 TurboDave said:
MJ/s vs 123 is like comparing apples with pears at the end of the day.
But we like banana's*tongue*
Kean
Member #: 341
aka T2clubby
South Staffs
I quite like pears, and frankly am quite offended at your remarks Dave.
I think its about time that the pear got some respect from you apple jockeys instead of being cast aside as some inferior deformed fruit.
*evil*
Kean
Member #: 341
aka T2clubby
South Staffs
Nice to see someone making the most of his fruit,
have you noticed any corelation between lemon size and voltage output?
Dangerous
Member #: 417
POTATO POWER
Leonard
Member #: 806
Cirencester, Gloucestershire
what kind of power will a lemon put out?
Kean
Member #: 341
aka T2clubby
South Staffs
probably about 0.2 bananas.................
It looks like your all getting your 5 a day!
Is that measured in volts or portions? *wink*
Gavin:)
I have never seen a topic go so OT, but be so interesting ever before!
On 23/03/2006 00:27:38 mini1071s said:
Just been told off by the ships cook
LMFAO!!!!!!!
Same as Tom. I'm nearly crying here, and that was an art I thought I's forgotten...:)
Dangerous
Member #: 417
On 23/03/2006 00:14:24 mini1071s said:
We hope to build this one as a lemon powered elecric mini if this job gets any more tedious...
How do you think it will compare to the orange power one*indifferent*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
If you want to push the lemon experiment...
try using jiff lemon juice
*wink*
Thats what I use with my students when they study battery technology.
Alex
AlexF
Mini_Andy
Member #: 432
this thread is quality.
its taken off topic to a new level :)
Kean
Member #: 341
aka T2clubby
South Staffs
If you rotate the said lemons can you produce alternating current?
Kean
Member #: 341
aka T2clubby
South Staffs
excellent, cant wait lol
All very interesting!
So with the current, you will need to measure these???
Kean
Member #: 341
aka T2clubby
South Staffs
I second that Mmmmmmmmm
You may like this - http://www.storewars.org/flash/index.html
Phil. *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
mmmmmm!
front row..... 2nd from the left
THAT MY AMP!!
*happy*
Alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
I am a Trace Elliot man!
