| Home > A-Series EFI / Injection > Inlet Manifold Design - Triple Injectors | |||||||
6th Jun, 2010 at 03:48:57pm
Sorted.
6th Jun, 2010 at 06:48:07pm
On 6th Jun, 2010 Paul S said:
.analise the flow patterns and maybe the pressure pulses. will that be requiring lubricant ?
8th Jun, 2010 at 09:25:52pm
I'm struggling to get a working copy of Ansys so I thought I would see what the Solidworks CFD feature would make of it.
8th Jun, 2010 at 10:46:59pm
very clever stuff, I wish I has the time to play and learn solid works better Team www.sheepspeed.com Racing
8th Jun, 2010 at 11:00:59pm
No offence Paul but to my untrained eye it just looks like a child scribbled all over it with a blue crayon. Isambard Kingdom Brunel said:
8th Jun, 2010 at 11:07:15pm
On 8th Jun, 2010 Paul S said:
The main restriction of the Solidworks CFD is that it only allows one inlet and one outlet, so I had to put a bung in one of the runners. Also it will not do transients. Instead of putting a bung in one of the runners could you not have the joint together with a Y piece to form a single outlet? Isambard Kingdom Brunel said:
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
8th Jun, 2010 at 11:38:55pm
top job Paul!!!
Nothing special! |
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
9th Jun, 2010 at 09:01:12am
Great work Paul, what addition of Solidworks are you using, is the CFD an add on package like Cosmos? 1972 998 TURBO SLEEPER |
9th Jun, 2010 at 09:24:31am
On 9th Jun, 2010 longy said:
Great work Paul, what addition of Solidworks are you using, is the CFD an add on package like Cosmos? It's Solidworks Office Premium 2010 64 bit. This is using the built in FloExpress Analysis Wizard. Apparently there is a piece of software called Solidworks Flow Simulation that does much more, like pressure profiles and transients. I've got my IT monkey sorting out a copy. On 8th Jun, 2010 Rob H said:
No offence Paul but to my untrained eye it just looks like a child scribbled all over it with a blue crayon. That's what Sturgeo said! I only wish I had the artistic skills to draw like that. On 8th Jun, 2010 Rob H said:
Instead of putting a bung in one of the runners could you not have the joint together with a Y piece to form a single outlet? Well, if you think about it, the inet only feeds one port at a time, once per engine cycle. So the above simulation is probably a nearer approximation. At no time does the flow in the inlet equal double the flow in the port as would be the case if I joined the trumpets at the outlet. The other software will allow the use of two outlets, so as long as I can apply pulsed flow to each then that should make useful data. Anyway, just realised that the decimal point was in the wrong place and I was putting enough flow though it for 90,000rpm, so I'm re-running the simulation with lower velocities. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Jun, 2010 at 10:07:39am
cheers Paul 1972 998 TURBO SLEEPER |
9th Jun, 2010 at 10:55:18am
Ok, I've now got flows equivalent to about 9000rpm on a 1275, so a little higher than reality.
9th Jun, 2010 at 03:31:42pm
Interesting data.
10th Jun, 2010 at 09:59:19am
The velocity profile in the ports is biased towards the side away from the inlet. By the time it has got to the valve area it should have even out. So I'm not sure if it is significant enough to warrant changing anything.
520 Posts Member #: 2093 Post Whore Grenoble, France |
10th Jun, 2010 at 11:09:45am
Paul I didn't read the entire thread, just took a look at your Solidworks sims.
Edited by alpa on 10th Jun, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
10th Jun, 2010 at 11:16:10am
On 10th Jun, 2010 alpa said:
The plenum works better when its section decreases toward the farthest runner, this creates a more balanced flow between runners, otherwise air misses the first runner, makes the best in the middle and does not go to the farthest. You'll find most of stock plenums of inline engines are like that. Doesn't the plenum on JK's Tubby TwinK reflect this design? If something is worth doing, it's worth doing half of. |
10th Jun, 2010 at 11:29:47am
The plenum works better when its section decreases toward the farthest runner, this creates a more balanced flow between runners, otherwise air misses the first runner, makes the best in the middle and does not go to the farthest. You'll find most of stock plenums of inline engines are like that. Doesn't the plenum on JK's Tubby TwinK reflect this design? Yes, JK's design follows that idea, but remember that he has 4 ports and it may be more critical. This exercise is purely to inform me whether I should carry on welding or add a taper between the inlet and the first trumpet. This software is CFD at its very basic level. I think that it will be interesting to see the results of a full blown CFD study with pressure profiles and pulses. If that shows that there are faults with the current design, then there will be a new design/construction at some point in the future. At the moment I can't see any problems that say that I should not carry on welding. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
10th Jun, 2010 at 01:34:40pm
Well, it looks like there may be benefits in adding the taper. A couple of iterative analises:
10th Jun, 2010 at 03:16:39pm
Surely, unless you can run a simulation of the two runners flowing at the same time - yes, I know that doesn't actually happen, but unless you simulate it - the effect of the taper on air favouring one runner or the other, can't be show.
10th Jun, 2010 at 03:35:53pm
As I said ^^^ this particular version of the software will only allow one inlet and one outlet plus it does not does transient simulations. So it has limited functionality.
10th Jun, 2010 at 04:07:14pm
This is what we need to do:
10th Jun, 2010 at 07:39:46pm
I've made the taper a bit longer:
1425 Posts Member #: 690 Post Whore Norfolk |
10th Jun, 2010 at 09:46:34pm
neat - if you fancy trying something else - put the inlet feeding into the middle of the two ports, front on or underneath
If Carling made Mini engines
11th Jun, 2010 at 08:02:57am
Paul, what you are basically prooving is that the intake path should not change air speed because every change is a source of reflections (impedance) .
Edited by alpa on 11th Jun, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
11th Jun, 2010 at 09:28:38am
On 11th Jun, 2010 alpa said:
Paul, what you are basically prooving is that the intake path should not change air speed because every change is a source of reflections (impedance) . I'm not sure that I agree with that statement. Extract from a definition of plenum: "Turbochargers deliver air at a relatively constant rate, while cylinders demand it in a varying manner, as the valves open and as piston speed varies through the stroke. Simple direct ducting would give problems where the nearest cylinders received more airflow. The pulsating demand from the cylinders would also show problems of either pressure waves in the duct, or a shortage of inlet air towards the end of the inlet phase. The solution is to provide a large-volume plenum chamber between the inlet and the cylinders. This has two benefits: it evens out the difference in path restriction between cylinders (distribution across space), secondly it provides a large-volume buffer against pressure changes (distribution over time)." Inevitably a "large-volume" will cause velocity to drop. It actually uses the drop in velocity to achieve the benefits. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
11th Jun, 2010 at 09:32:43am
On 10th Jun, 2010 johnK said:
neat - if you fancy trying something else - put the inlet feeding into the middle of the two ports, front on or underneath JK That's what I did with the 998T manifold. There was a lengthy discussion in this thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=154962 I can't go in the front with this one because of the fuel rails, but I can go in the top. The only problem I foresee is that it will need a tight bend to get it under the bonnet line. The bend will induce some swirl before it enters the plenum which may cause uneven distribution. I knock another one out later once I've done some work. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
